Recover external storage with encryption
  1. Enable server-side encryption and encryption app.
  2. Add an external storage and make it available to group Group1. (storage type: Local)
  3. With userA (in Group1), upload some file to the ext storage, and it gets encrypted.
  4. With admin, delete the external share from Admin page ( note, the UI does not give any warnings on consequences, it’s deleted with just one click).
  5. With admin, add the external storage back again, with same parameters as before.
  6. UserA though still see the ext storage and the file, but is unable to decrypt it anymore.
7. UserA should be able to encrypt it again, because nothing had been changed, only detached and attached the external storage.
8. UserA is unable to decrypt the file.
Operating system: CentOS7
Web server: apache httpd
Database: maria
ownCloud version (see ownCloud admin page): 9.1.2(stable)
Integrity status for oC9+
Has anyone every experience such problem or help to do a test see if it’s reproducible on your side?
