- ssh to owncloud instance
- add env variable export OC_RECOVERY_PASSWORD=‘recoverypassword’
- set OC_RECOVERY_PASSWORD=‘recoverypassword’
- sudo -u daemon php -d memory_limit=-1 /opt/bitnami/owncloud/occ encryption:decrypt-all -m recovery username
Tell us what should happen:
Decrypt all files for the specified user
Tell us what happens instead:
Fails with error: “In DecryptAll.php line 204: invalid credentials provided”
We ensured that password is correct and correctly resides in environment variables.
Operating system: Debian GNU/Linux 10
Server version: Apache/2.4.53 (Unix)
Server built: Mar 14 2022 13:20:59
MariaDB
v3.4.0
10.10.0.3
fresh
Bitnami package
<?php
$CONFIG = array (
'passwordsalt' => '---',
'secret' => '---',
'datadirectory' => '/bitnami/owncloud/data',
'overwrite.cli.url' => 'http://localhost',
'dbtype' => 'mysql',
'version' => '10.10.0.3',
'dbname' => 'bitnami_owncloud',
'dbhost' => '127.0.0.1:3306',
'dbtableprefix' => 'oc_',
'mysql.utf8mb4' => true,
'dbuser' => '---',
'dbpassword' => '---',
'allow_user_to_change_mail_address' => '',
'http.cookie.samesite' => 'None',
'logtimezone' => 'Europe/Moscow',
'maintenance' => false,
'enable_certificate_management' => true,
'apps_paths' =>
array (
0 =>
array (
'path' => '/opt/bitnami/owncloud/apps',
'url' => '/apps',
'writable' => false,
1 =>
array (
'path' => '/opt/bitnami/owncloud/apps-external',
'url' => '/apps-external',
'writable' => true,
'installed' => true,
'instanceid' => 'oct9m86qmso2',
'mail_domain' => '---',
'mail_from_address' => '---',
'mail_smtpmode' => 'smtp',
'mail_smtphost' => '---',
'mail_smtpport' => '25',
'memcache.local' => '\\OC\\Memcache\\Redis',
'redis' =>
array (
'host' => '/var/run/redis/redis-server.sock',
'port' => 0,
'password' => '',
'dbindex' => 0,
'ldapIgnoreNamingRules' => false,
'openid-connect' =>
array (
'auto-provision' =>
array (
'enabled' => true,
'email-claim' => 'email',
'display-name-claim' => 'name',
'mode' => 'userid',
'search-attribute' => 'preferred_username',
'provider-url' => '---',
'client-id' => '---',
'client-secret' => '---',
'loginButtonName' => 'SSO',
'singleuser' => true,
'trusted_domains' =>
array (
0 => 'localhost',
1 => '---',
**List of activated apps:**
no
yes
SELECT * FROM oc_appconfig
WHERE appid
= ‘user_ldap’;
### Client configuration
**Browser:**
**Operating system:**
### Logs
#### Web server error log
#### Browser log
c) …
