Hi there forum,
Allthough I’ve got a trusted domain setting my (new) owncloud server redirects to localhost.
Old server: Ubuntu 14.04, Apache 2.4, php5.6
New server: Ubuntu 16.04, Apache 2.4, php7.0
Owncloud the same on both servers 9.0.0.19
I’ve been running owncloud on a leftover pc I had laying around. Together with some WordPress sites I host for myself. The hardware got outdated so I decided to move to new hardware… starting with owncloud.
I kept the original server in place and changed the vhost file with a proxy pass to the new hardware:
root@precious:/etc/apache2# cat sites-enabled/owncloud.conf
<Virtualhost *:80>
ServerAdmin *********@gmail.com
ServerName oc.bilbos-stekkie.com
ProxyPass / http://oc.bilbos-stekkie.com/
ProxyPassReverse / http://oc.bilbos-stekkie.com/
Because the host oc.bilbos-stekkie.com is resolved as a public IP I’v placed an entry in /etc/host like so
root@precious:/etc/apache2# grep oc.bilbos /etc/hosts
192.168.5.7 oc.bilbos-stekkie.com
With this in place the old server (192.168.5.2) should now be redirecting traffic to the new server (192.168.5.7)
On the new server I’v got the following vhost file:
root@precious-2017:/var/www/owncloud/config# cat /etc/apache2/sites-enabled/owncloud.conf
<Virtualhost *:80>
ServerAdmin *******@gmail.com
DocumentRoot /var/www/owncloud
#ServerAlias www.your-domain.com
<Directory "/var/www/owncloud">
Options +FollowSymLinks
AllowOverride All
<IfModule mod_dav.c>
Dav off
</IfModule>
SetEnv HOME /var/www/owncloud
SetEnv HTTP_HOME /var/www/owncloud
</Directory>
<Directory "/var/www/owncloud/data/">
# just in case if .htaccess gets disabled
Require all denied
</Directory>
ErrorLog /var/log/apache2/owncloud/error_log
CustomLog /var/log/apache2/owncloud/access_log common
</Virtualhost>
The owncloud config has the trusted domain array set
array (
0 => 'oc.bilbos-stekkie.com',
I’ve even made an entry in /etc/hosts for oc.bilbos-stekkie.com… but that didn;t help… I stll get redirected to localhost.
The apache log of a request is:
192.168.5.2 - - [28/Jul/2017:22:54:39 +0200] “GET / HTTP/1.1” 302 1320
http code 302 being a redirect (to localhost?)
I’m at a loss at the moment… I anyone could help? please ![]()
Peter
