- Attempt to open or upload file or create new folder;
- Opening file redirects to “Internal Server Error” page;
- Uploading or creating triggers “NOAUTH Authentication required” popup.
sudo cat data/owncloud.log | grep AUTHindicates Redis Exception
File should just open or upload or folder should be created.
Authentication error is thrown indicating Redis Exception.
Operating system: Ubuntu 20.04
Web server: Apache2
PHP version: 7.4
ownCloud version: (see ownCloud admin page) 10.5.0.10
Where did you install ownCloud from: ```
owncloud community owncloud-10.5.0.tar.bz2
**Signing status (ownCloud 9.0 and above):** Let's Encrypt HTTPS
https://gist.github.com/michaelgill1969/397ecf1989208b3bd17776ff00876c89
"basic": {
"license key": "***REMOVED SENSITIVE VALUE***",
"date": "Thu, 22 Oct 2020 20:15:34 +0000",
"ownCloud version": "10.5.0.10",
"ownCloud version string": "10.5.0",
"ownCloud edition": "Community",
"server OS": "Linux",
"server OS version": "Linux ubuntu-s-1vcpu-1gb-nyc1-01 5.4.0-52-generic #57-Ubuntu SMP Thu Oct 15 10:57:00 UTC 2020 x86_64",
"server SAPI": "apache2handler",
"webserver version": "Apache\/2.4.41 (Ubuntu)",
"hostname": "owncloud.michaelgill1969.me",
"logged-in user": "admin_michael"
"stats": {
"users": {
"Database": {
"count": 2,
"seen": 2,
"logged in (30 days)": 2
"groups": {
"OC\\Group\\Database": 2
"config": {
"instanceid": "octe9oh7qpqz",
"trusted_domains": [
"localhost",
"161.35.53.135"
"datadirectory": "\/var\/www\/owncloud.michaelgill1969.me\/data",
"overwrite.cli.url": "https:\/\/owncloud.michaelgill1969.me",
"dbtype": "mysql",
"version": "10.5.0.10",
"dbname": "owncloud",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"mysql.utf8mb4": true,
"logtimezone": "UTC",
"apps_paths": [
"path": "\/var\/www\/owncloud.michaelgill1969.me\/apps",
"url": "\/apps",
"writable": false
"path": "\/var\/www\/owncloud.michaelgill1969.me\/apps-external",
"url": "\/apps-external",
"writable": true
"installed": true,
"redis": {
"host": "localhost",
"port": 6379
Enabled:
- calendar: 1.6.4
- comments: 0.3.0
- configreport: 0.2.0
- contacts: 1.5.5
- dav: 0.6.0
- federatedfilesharing: 0.5.0
- federation: 0.1.0
- files: 1.5.2
- files_external: 0.7.1
- files_mediaviewer: 1.0.3
- files_sharing: 0.13.0
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- firstrunwizard: 1.2.0
- market: 0.6.0
- notifications: 0.5.2
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- tasks: 0.9.7
- updatenotification: 0.2.1
Disabled:
- encryption
- external
- user_external
Are you using external storage, if yes which one: local/smb/sftp/… no
Are you using encryption: yes/no no
Are you using an external user-backend, if yes which one: LDAP/ActiveDirectory/Webdav/… no
Browser: Firefox
sudo cat data/owncloud.log | grep NOAUTH
{"reqId":"same as indicated by phpinfo() diagnostics","level":4,"time":"2020-10-22T19:55:59+00:00","remoteAddr":"45.56.142.231","user":"*********","app":"webdav","method":"GET","url":"\/remote.php\/webdav\/ownCloud%20Manual.pdf","message":"Exception: NOAUTH Authentication required.: {\"Exception\":\"RedisException\",\"Message\":\"NOAUTH Authentication required.\"
