This is my first post, Kudos to everyone from the OwnCloud Community!
V: ownCloud 9.1.0
So, basically my problem is:
I have the cloud, online, where my clients/users register. I then create a master folder with subfolders, upload pictures to the subfolders with a standard name, share the master folder with the client/user, then the client/user rename the subfolders to whatever he wants.
The problem arises when the folder is not renamed in local, in my sync-folder, on my computer.
Thanks in advance!
Hot
EDIT:
So I basically solved the renaming problem on windows, but I still get it with mac OS. Guesses?
PROBLEM 2
I’m now trying to upload some videos to the users folder but I can’t.
The videos are .mp4 of about 800MB.
I’m aware of the 512MB limit.
I tried the following:
Rise limit in onwcloud .user.ini, config.ini, .htaccess
Same for the website root.
But with no success, the upload hangs, both from local folder and webui, and then simply stops/disappear.
I can upload from FTP but this is not the best solution for me.
user_photos is shared with 3 users, tried renaming folder1/folder2, from either:
the web UI
the desktop client
And I’m not being able to reproduce this behavior, since in all cases, every account synced with the client displays a notification, and therefore the folder is renamed locally:
So, let’s try to find out what’s going on with your version of the client by looking at some logs: ownCloud Documentation Overview Can you append them here?
