Hi all,
I have an owncloud server with an external harddrive used as storage. A few days ago this harddrive broke.
Is there a way to replace the harddrive? I’m afraid that when I replace the drive with an empty one, things will get messed up. According to the database the files should be there, but owncloud will not find them on the drive. Will it start removing this data out of the database? Will it start removing this data from the clients who are synchronizing their data?
Maybe I should do a kind of reset of the database? Or maybe a whole new installation is the best option?
Any suggestions?
Thanks in advance
Matthias
