I am trying to set up ownCloud on my QNAP NAS.
Following the official installation guide I think I made a mistake at the very beginning.
I would like to use an IP adress instead of a domain. but I put the IP here:
my_domain=β192.168.0.100β (using my real IP of course)
echo $my_domain
hostnamectl set-hostname $my_domain
hostname -f
now I am getting an error/issue with apache2.conf.
If I use following command to overwrite the above will that cause problems, or work at all?
I strongly encourage you reconsider that idea. You need to use HTTPS to protect your data and your NAS device. HTTPS requires a certificate. Most certificates require a domain name for validation. Attempting to use only an IP address will create substantial and unnecessary security risks and makes normal operations far more difficult than they should be.
You also are not using the hostname command in a manner consistent with its purpose or capabilities. While I havenβt seen your Apache config, and canβt say that I want to, I have no doubt that you need to correct errors in it as well.
I donβt know what degree of QNAP support is available here, nor can I comment on the ownCloud support available on the QNAP forums, but it may not hurt to see if QNAP has any hits to guides.
Not quite yet, I still have to get either a static IP from my ISP or go for DynDNS. Will head forward on Monday. Thanks for asking. Have a nice Weekend.
