Requesting and downloading from RESTful API
Hello Guys,
I’m trying to download files from the REST-API of owncloud. but I think that the API which I found in the internet is not actual. Because by trying to download a file via URL in the Browser always get redirected to my owncloud site.
And If I look at the Request which a get from the “Postman”, it gives me a whole HTML-Site, but the files are not shown, because I get this message: “Access your files via webdav”.
If i understood it right, the owncloud site loads the pictures with javascript via webdav.
Here is the Restful API, which I use to get the files: RESTful API · owncloud/gallery Wiki · GitHub
This link shows the SHARE API(I think it is not necessary for my request), which prodives just information about the filesystem in the oC as xml-format. ownCloud Documentation Overview
I would appreciate any comments and help.
Thanks,
Kesking03
There is no REST api for files. ownCloud is based on WebDAV.
Please use a webdav library and connect to http://example.com/remote.php/dav
okay, do I have to download a owncloud Desktop Client?
and configure a WebDav Server or just connect to the server(I don’t know how exactly)?
Maybe this helps: ownCloud Documentation Overview
thanks, it solved my problem bro.
the roadmap of develop not have this feature on plans?
No - we use webdav as our api. Webdav is an open standard for file access via http as well as syncing calendar and contacts.
Adding any additional api is out of scope
