RESOLVED: Need help fixing a failed update from 10.2.1.4 to 10.3.2.2
  1. Log into owncloud’s Web interface
  2. Click on the upgrade button
  3. See the error message
I was upgrading from ownCloud 10.2.1.4 to current version using the updater. I would have expected the upgrader to conclude successfully and give me access to the Web interface for the latest version 10.3.2.2
The upgrader exited with an error message:
== begin error message ==
Updating to 10.3.2
Repair warning: You have incompatible or missing apps enabled that could not be found or updated via the marketplace.
Repair warning: Please install or update the following apps manually or disable them with: occ app:disable ownbackup
Repair warning: For manually updating, see doc.owncloud. org/ server/ 10.3/ go.php?to=admin-marketplace-apps
Detailed logs:
Preparing update
Set log level to debug
Turned on maintenance mode
Repair warning: For manually updating, see doc.owncloud.org/ server/ 10.3/ go.php?to=admin-marketplace-apps
The update was unsuccessful. Please report this issue to the ownCloud community.
== end error message ==
PRETTY_NAME=“Debian GNU/Linux 8 (jessie)”
NAME=“Debian GNU/Linux”
VERSION_ID=“8”
VERSION=“8 (jessie)”
ID=debian
Distributor ID: Debian
Description: Debian GNU/Linux 8.11 (jessie)
Release: 8.11
Codename: jessie
Apache
Server type: MySQL
Server version: 5.5.60-0+deb7u1-log - (Debian)
Protocol version: 10
php7.2
10.2.1.4 in the process of upgrading to 10.3.2.2
downloaded from owncloud.org
Cannot login to admin user in my owncloud to access the resource since owncloud is displaying only the error message or the upgrade button option
‘admin’ -> ‘Generate Config Report’ -> ‘Download ownCloud config report’
Cannot log into the web-UI
Don't have access to the sudo command with my privileges on the webhosting command line.
Executing the command without sudo to the www-data user results in an error as the wrong PHP version is being used.
Executing the occ command without sudo to the www-data user results in an error as the wrong PHP version is being used in this virtual host environment.
no
yes
no
Safari
macOS Catalina
don't have access to the Webserver log
All of the 18+ MB of log file? You must be kidding. What about sensitive user-identifying data? Cannot possibly go through huge file to get rid of it all.
It's not a browser issue.
it looks to me that the following message should provide all needed information on how to continue with your update or am i wrong?
Hey @anon21401411,
one would think so. But I have only access to a limited shell in this virtual hosting environment. There is no sudo command. And without it I cannot sudo to the www-data user to execute the occ command. And with the wrong user credentials the wrong php version gets used, old, deprecated, no idea why they keep that shit. php 4.4.9. So execution of occ command fails.
In this case you can
  • backup the ownbackup directory in the apps folder
  • delete the the complete folder ownbackup
  • restart the upgrade
  • restore the ownbackup folder
  • ownCloud will probably show an upgrade button again (now this refers to the app)
Now your ownCloud should be running.
It might be possible, that the updater complains about some other apps, look for the line
Repair warning: Please install or update the following apps manually or disable them with: occ app:disable <app name>
then the ownCloud upgrade must be performed with those apps removed.
Thank you, @cortho!
moved the ownbackup dir outside of the owncloud installation (one level higher than owncloud install dir).
Tried update. Same error. Where else is that information about that app contained? Can it be fixed with a simple text-editor? or a delete? copy and paste?
You can also disable an app in the database by setting configvalue to no in the row where appid = ownbackup and configkey = enabled.
! Be careful !
@eneubauer Thanks. Will try that.
@eneubauer thank you Erik.
That worked like a charm! I’m back in the user interface and can do stuff! :slight_smile:
Thank you :pray: very much. You’re my hero! :+1:
