Hi.
I’m hoping for some general information in relation to what I might expect if I restore the database (current v10.x.x production) from a 2 month old backup, whilst maintaining the existing data directory. The latter is mounted from an external NFS share.
I had an issue with a VM that forced me to go back to this time. My clients do not necessarily maintain all their files on every device, so assume some are only in the data file cache (still in tact).
Is their a method to ensure all the backend data files are synchronized with the earlier database restore.
I see a lot of posts on people losing the data cache and then relying on client re sync, but not much for when the database goes back in time and there are files in the cache that are current and no where else.
I also have external storage for cloud services and a local photo repository on a NAS. I assume these are unaffected, as it appears a one way operation whereby OC will simply make available whatever is in the external storage and not manage the files in any other way, i.e remove them if the db says they don’t exist…
I see the digital fingerprint is a recommended step after a restore of either data or database (as published in the help). Does this assist in recovering already cached files back into the database. I have used scan before to resolve issues. Are there any other maintenance commands that would be recommended in this scenario.
Any info would be appreciated. I;m leaving the VM off until I get a better understanding. I’ve backed up the data folder and everything else is in the VM (also backed up).
My issue was to not have a daily backup of the database, so that has now been corrected.
Thanks again.
Jeff.
