I just upgraded my server (currently running Owncloud 10.0) to RHEL 8 from RHEL 7. I’m not seeing a RHEL8 repos. Does that mean I need to use the tarballs for ugrading Owncloud?
RHEL 8.6
Apache 2.4.37
Maria DB 15.1
10.3.2
Upgrade
RHEL7 Repos
