Root directory on firstrunwizard - picture not visibel
I have a problem on first login on user for see some pictures.
url on my cloud:
https://10.10.10.33/**owncloud**/index.php/apps/files/?dir=/&fileid=975
i see that the root folder on url picture are not. I use a personal Themes.
Wher is for changing thant ?
in whating of your help.
Best regard
chris
did you had a look at this ?
https://doc.owncloud.com/server/10.0/developer_manual/core/theming.html
hello,
Thank’s for the link, but i have questions.
in now i haven’t permission on the log see under:
:/home/administrateur/Documents# ./theme-bootstrap.sh TEMP /var/www-https/html/owncloud
Bootstrapping theme development.
Copying default theme
cp: cannot stat ‘/var/www-https/html/owncloud/apps/theme-example’: No such file or directory
Updating theme id
sed: can’t read /var/www-https/html/owncloud/apps/TEMP/appinfo/info.xml: No such file or directory
Setting theme file permissions
chown: cannot access ‘/var/www-https/html/owncloud/apps/TEMP’: No such file or directory
Enabling theme
TEMP not found
Finished bootstrapping the new theme.
i see that ne new theme is under “/apps/” but on on config.php i put the line ‘theme’ => ‘NewTheme’,
that the path on my Theme:
/var/www-https/html/owncloud/themes/NewTheme
I don’t realy understand the tow way of theme.
Than’s for explane.
Best regrad’s
You have to download the theme-example app first, then execute the script with 2 variables set - the theme name and the path to your ownCloud root folder.
