Running in Docker `.well-known/caldav` redirects to the internal hostname/port
  1. https://my-owncloud.xyz/.well-known/caldav
Redirects to: https://my-owncloud.xyz/remote.php/dav/
  • httpss
  • no port 8080
It redirects to http://my-owncloud.xyz:8080/remote.php/dav/
Operating system: Docker image: owncloud/server:10.15.1
Web server: see Docker image
Database: not relevant
PHP version: see Docker image
ownCloud version: 10.15.1
Updated from an older ownCloud or fresh install: no
Where did you install ownCloud from: Docker image
Signing status (ownCloud 9.0 and above): `No errors have been found.
<?php
$CONFIG = array (
  'apps_paths' =>
  array (
    0 =>
    array (
      'url' => '/apps',
      'writable' => false,
    1 =>
    array (
      'path' => '/var/www/owncloud/custom',
      'url' => '/custom',
      'writable' => true,
  'trusted_domains' =>
  array (
    0 => 'my-owncloud.xyz',
  'datadirectory' => '/mnt/data/files',
  'dbtype' => 'mysql',
  'dbhost' => 'oc-mariadb:3306',
  'dbname' => 'owncloud',
  'dbuser' => '***',
  'dbpassword' => '***',
  'dbtableprefix' => 'oc_',
  'log_type' => 'owncloud',
  'supportedDatabases' =>
  array (
    0 => 'sqlite',
    1 => 'mysql',
    2 => 'pgsql',
  'upgrade.disable-web' => true,
  'default_language' => 'en',
  'overwrite.cli.url' => 'http://my-owncloud.xyz/',
  'htaccess.RewriteBase' => '/',
  'logfile' => '/mnt/data/files/owncloud.log',
  'mysql.utf8mb4' => true,
  'passwordsalt' => '***',
  'secret' => '***',
  'version' => '10.15.1.0',
  'dbconnectionstring' => '',
  'logtimezone' => 'UTC',
  'installed' => true,
  'instanceid' => '***',
Enabled:
  - activity:
    - Version: 2.7.2
  - calendar:
    - Version: 2.0.0
    - Path: /var/www/owncloud/custom/calendar
  - comments:
    - Version: 0.3.0
  - configreport:
    - Version: 0.3.0
  - dav:
    - Version: 0.7.0
  - diagnostics:
    - Version: 0.2.1
    - Path: /var/www/owncloud/apps/diagnostics
  - federatedfilesharing:
    - Version: 0.5.0
  - federation:
    - Version: 0.1.0
  - files:
    - Version: 1.6.0
  - files_external:
    - Version: 0.9.0
  - files_mediaviewer:
    - Version: 1.0.5
  - files_pdfviewer:
    - Version: 1.0.2
  - files_sharing:
    - Version: 0.14.0
  - files_texteditor:
    - Version: 2.6.1
    - Path: /var/www/owncloud/apps/files_texteditor
  - files_trashbin:
    - Version: 0.9.1
  - files_versions:
    - Version: 1.3.0
  - firstrunwizard:
    - Version: 1.3.0
  - market:
    - Version: 0.9.0
  - notifications:
    - Version: 0.6.0
  - provisioning_api:
    - Version: 0.5.0
  - systemtags:
    - Version: 0.3.0
  - updatenotification:
    - Version: 0.2.1
Are you using external storage, if yes which one: n/a
Are you using encryption: no
