S3 connectivity
I have an S3 compatible provider which I would like to use as primary storage for owncloud.
I can connect it using External storage (files_external_s3 app), and I use it to find the correct configuration, but not I’ve found it, I would like to use the same parameters for primary storage.
Unfortunately, it doesn’t work, or, more likely, I don’t know how to set it right.
Here is the config that works:
How should the config.php file look like ? I know I have to use this link, but no luck now ?
Thanks for your help !
This is the wrong link. It is pointing to the documentation for setting up S3 as primary storage.
This is the correct link.
Enable path style is usually not required (and is, in fact, incompatible with newer Amazon datacenters), but can be used with non-Amazon servers where the DNS infrastructure cannot be controlled. Ordinarily, requests will be made with http://bucket.hostname.domain/ , but with path style enabled, requests are made with http://hostname.domain/bucket instead.
Perhaps try disabling path style?
Also if you still have no luck, please check the ownCloud log.
Finally you neglected to fill out the post template, it will greatly help in the forum users being able to help you. Here it is again:
I really think you misunderstood what I really try to do : I want to set up S3 storage as primary storage. I use external storage extension to find the correct settings for my S3 backend, and I found it, as shown in the picture (green circle).
Whant I want to do, is to use this settings in config.php
Ah sorry, files_external_s3 is only for external storage configuration.
If you want to use S3 as primary storage you need to use files_primary_s3:
https://marketplace.owncloud.com/apps/files_primary_s3
So disable the other app, and install this one. Then you should be able to access S3 using one of the configurations from the documentation:
https://doc.owncloud.com/server/10.9/admin_manual/configuration/files/external_storage/s3_compatible_object_storage_as_primary.html#configuration
Please provide the information from the post template like a config report, then we can tell for sure which app you have installed.
