Same file re-sync
Hi :slight_smile:
I have a problem with file sync:
I uploaded from my business connexion (1Gb/s) all my pictures to my owncloud server (with web browser)
I have, on my PC at home the same folder witch i want to sync.
Files are the same on the both side, but when i launch owncloud client, it resync every file ! And i don’t know why…
Am i doing something wrong?
I can’t sync with my home connexion 100 GB pictures, it would take an eternity…
The ownCloud sync client is currently not detecting this:
Ok thank you for your answer, maybe in a future version :frowning:
there is a developer assigned to the second feature request so this might be included in one of the next major releases.
Also forgot to mention that there is a possible workaround to copy the sync state database between clients. You will find a description for this in the following comment:
