Schedule Sync in owncloud
I wonder if it is possible to set up a schedule to timing.
How do I setup this task?
I am not entirely sure what that would mean, so I guess the answer is no. The sync client aims to sync your local files with the server as fast as possible so that both sides are possibly always in the exact same state.
Hi @dragotin I like this option, sometimes is good to have the chance to configure sync time schedule, like… I have a folder with SQL Server backup, I want to sync during midnight, so this option is Good.
Ah, I see. In that case, I would recommend to use owncloudcmd which is our commandline client to sync, see the docs.
You could add a call to it to your backup script, so that the last step synchronizes.
