Search box results are ok but not displayed without scrolling on 8.2.11
1.type a word in searchbox to find filename with this word
2.received the correct number of files found : 3 but the filelist is empty
See the 3 files without having to scroll down
I need to scroll down and redo the search
Operating system: Debian
Apache 2
Mysql
8.2.11
updated
Please consider updating to 10.0.3
is it a normal behavior for 8.x ? I can’t really upgrade now for compatibility issues but the users are not using the system because of it
I don’t know, I suspect an error, but I can’t help you because 8.2 is out of life.
Maybe another user who still uses 8.2 can help you out.
thanks! i know we should upgrade but it is not an option for now…
