we have a phone system server that saves users voice mails into a directory (usr/local/pbx/voicemails)
inside voicemail, there is several directory- each Phone System user has their own directory - and the directory is the users domain name
now, i want to interconnect with OwnCloud, so users can login to OC and see their files, share it with others, sync it between devices etc
so, how will i accomplish this?
i planned on making “recordings” a NFS mount to the OwnCloud server
and when i add a user to OC, it will make that users home directory the specific domain folder inside “recordings”, and the user shouldnt be able to change into another directory, outside from thier domain folder
but, when i add a user to OwnCloud, how can i specify which directory the user should have access to ?
ownCloud configuration
Go to the admin page, click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' or use the command line `sudo -u www-data php occ config:list system` (please sanitize sensitive data):
You probably can mount different NFS shares at each user’s directory. For internal storage, you can’t easily change the structure how ownCloud manages users. It used to be possible to mount external storage as the user’s home folder in the enterprise edition but I don’t find the reference again.
Your second request is probably difficult. Not sure how this can be done on home storage. You could just use the default ownCloud storage and connect to NFS via external storages and you manage permissions there in a way you want them to be.
If the enterprise subscription is an option for you, their support can probably help you best, which of your goals can be achieved. On the community version, you probably have to live with a work around or start implementing it yourself.
i dont want to have to create a NFS mount for each user
rather, i want to create a user, and tell it where its home directory will be.
and they should not be able to access any folders above them (since if they do , then there will be a bunch of folders for each other user, which they will be able to see,. and i dont want them to see it)
