1.install the External Storage app
2.Choose SMB off the storage list
3.Fill in the fields and get a Green Dot
I see the folder on my list to open it
Click on the folder and get the Storage Not Available message
Operating system: MX16 - Debian 8 based linux
ownCloud version: (see ownCloud admin page) 9.1.6
Where did you install ownCloud from: owncloud website
https://gist.github.com/anonymous/9b59fa64a12790c126bafb3fab0109cf.js
Could not open file occ
Are you using external storage, if yes which one: smb
Are you using encryption: no
Exception: {“Exception”:“OCP\Files\StorageNotAvailableException”,“Message”:“Unknown error (Connection to 192.168.1.100 failed (Error NT_STATUS_HOST_UNREACHABLE))”,“Code”:0,“Trace”:“#0 /var/www/owncloud/apps/files_external/lib/Lib/Storage/SMB.php(289): OCA\Files_External\Lib\Storage\SMB->getFileInfo(‘’)\n#1 /var/www/owncloud/lib/private/Files/Storage/Common.php(436): OCA\Files_External\Lib\Storage\SMB->stat(‘’)\n#2 /var/www/owncloud/apps/files_external/lib/Lib/Storage/SMB.php(638): OC\Files\Storage\Common->test()\n#3 /var/www/owncloud/apps/files_external/lib/config.php(231): OCA\Files_External\Lib\Storage\SMB->test(false, false)\n#4 /var/www/owncloud/apps/files_external/lib/Controller/StoragesController.php(255): OC_Mount_Config::getBackendStatus(‘\\OCA\\Files_Exte…’, Array, false, false)\n#5 /var/www/owncloud/apps/files_external/lib/Controller/UserGlobalStoragesController.php(119): OCA\Files_External\Controller\StoragesController->updateStorageStatus(Object(OCA\Files_External\Lib\StorageConfig), false)\n#6 [internal function]: OCA\Files_External\Controller\UserGlobalStoragesController->show(1, false)\n#7 /var/www/owncloud/lib/private/AppFramework/Http/Dispatcher.php(159): call_user_func_array(Array, Array)\n#8 /var/www/owncloud/lib/private/AppFramework/Http/Dispatcher.php(89): OC\AppFramework\Http\Dispatcher->executeController(Object(OCA\Files_External\Controller\UserGlobalStoragesController), ‘show’)\n#9 /var/www/owncloud/lib/private/AppFramework/App.php(99): OC\AppFramework\Http\Dispatcher->dispatch(Object(OCA\Files_External\Controller\UserGlobalStoragesController), ‘show’)\n#10 /var/www/owncloud/lib/private/AppFramework/Routing/RouteActionHandler.php(46): OC\AppFramework\App::main(‘UserGlobalStora…’, ‘show’, Object(OC\AppFramework\DependencyInjection\DIContainer), Array)\n#11 [internal function]: OC\AppFramework\Routing\RouteActionHandler->__invoke(Array)\n#12 /var/www/owncloud/lib/private/Route/Router.php(280): call_user_func(Object(OC\AppFramework\Routing\RouteActionHandler), Array)\n#13 /var/www/owncloud/lib/base.php(891): OC\Route\Router->match(‘/apps/files_ext…’)\n#14 /var/www/owncloud/index.php(54): OC::handleRequest()\n#15 {main}”,“File”:“/var/www/owncloud/apps/files_external/lib/Lib/Storage/SMB.php”,“Line”:172}
#### Browser log
c) …
I am a pretty new at this so I get lost with a lot of the tech talk. My External storage is a USB drive off of my router. I can access it from the browser and from the file manager. Once I can see the drive and files on it from the server then I will work on accessing from a desktop client
