Hi to all, i have several errors on owncloud logs for a few users like as follows:
Nov 7 19:48:02 ocmx1 ownCloud[1113037]: [3bb2b94f-d258-448f-b782-92c9d9c26192][192.168.22.30][davide.marchi][no app in context][PROPFIND][/remote.php/dav/files/davide.marchi/] Error while trying to create shared mount
and immediately before that log
Nov 7 19:48:02 ocmx1 ownCloud[1113037]: [3bb2b94f-d258-448f-b782-92c9d9c26192][192.168.22.30][davide.marchi][no app in context][PROPFIND][/remote.php/dav/files/davide.marchi/] Exception: {“Exception”:“OCP\Files\NotFoundException”,“Message”:"",“Code”:0,“Trace”:"#0 /var/www/owncloud/lib/private/Share20/DefaultShareProvider.php(402): OC\Share20\Share->getNode()\n#1 /var/www/owncloud/lib/private/Share20/Manager.php(1200): OC\Share20\DefaultShareProvider->updateForRecipient()\n#2 /var/www/owncloud/lib/private/Share20/Manager.php(1190): OC\Share20\Manager->updateShareForRecipient()\n#3 /var/www/owncloud/apps/files_sharing/lib/SharedMount.php(118): OC\Share20\Manager->moveShare()\n#4 /var/www/owncloud/apps/files_sharing/lib/SharedMount.php(100): OCA\Files_Sharing\SharedMount->updateFileTarget()\n#5 /var/www/owncloud/apps/files_sharing/lib/SharedMount.php(72): OCA\Files_Sharing\SharedMount->verifyMountPoint()\n#6 /var/www/owncloud/apps/files_sharing/lib/MountProvider.php(87): OCA\Files_Sharing\SharedMount->__construct()\n#7 /var/www/owncloud/lib/private/Files/Config/MountProviderCollection.php(82): OCA\Files_Sharing\MountProvider->getMountsForUser()\n#8 [internal function]: OC\Files\Config\MountProviderCollection->OC\Files\Config\{closure}(*** sensitive parameters replaced )\n#9 /var/www/owncloud/lib/private/Files/Config/MountProviderCollection.php(83): array_map()\n#10 /var/www/owncloud/lib/private/Files/Filesystem.php(446): OC\Files\Config\MountProviderCollection->getMountsForUser()\n#11 /var/www/owncloud/apps/files_sharing/lib/SharedStorage.php(103): OC\Files\Filesystem::initMountPoints()\n#12 /var/www/owncloud/apps/files_sharing/lib/SharedStorage.php(456): OCA\Files_Sharing\SharedStorage->init()\n#13 /var/www/owncloud/lib/private/Files/Storage/Wrapper/Wrapper.php(500): OCA\Files_Sharing\SharedStorage->getWrapperStorage()\n#14 /var/www/owncloud/apps/files_sharing/lib/SharedStorage.php(130): OC\Files\Storage\Wrapper\Wrapper->instanceOfStorage()\n#15 /var/www/owncloud/lib/private/legacy/util.php(163): OCA\Files_Sharing\SharedStorage->instanceOfStorage()\n#16 /var/www/owncloud/lib/private/Files/Storage/StorageFactory.php(100): OC_Util::{closure}( sensitive parameters replaced )\n#17 /var/www/owncloud/lib/private/Files/Storage/StorageFactory.php(82): OC\Files\Storage\StorageFactory->wrap()\n#18 /var/www/owncloud/lib/private/Files/Mount/MountPoint.php(142): OC\Files\Storage\StorageFactory->getInstance()\n#19 /var/www/owncloud/lib/private/Files/Mount/MountPoint.php(165): OC\Files\Mount\MountPoint->createStorage()\n#20 /var/www/owncloud/lib/private/Files/View.php(1476): OC\Files\Mount\MountPoint->getStorage()\n#21 /var/www/owncloud/lib/private/Files/Node/Root.php(190): OC\Files\View->getFileInfo()\n#22 /var/www/owncloud/lib/private/Files/Node/Root.php(363): OC\Files\Node\Root->get()\n#23 /var/www/owncloud/lib/private/Server.php(1055): OC\Files\Node\Root->getUserFolder()\n#24 /var/www/owncloud/apps/dav/lib/Server.php(285): OC\Server->getUserFolder()\n#25 /var/www/owncloud/lib/composer/sabre/event/lib/WildcardEmitterTrait.php(89): OCA\DAV\Server->OCA\DAV\{closure}( sensitive parameters replaced ***)\n#26 /var/www/owncloud/lib/composer/sabre/dav/lib/DAV/Server.php(456): Sabre\DAV\Server->emit()\n#27 /var/www/owncloud/lib/composer/sabre/dav/lib/DAV/Server.php(253): Sabre\DAV\Server->invokeMethod()\n#28 /var/www/owncloud/apps/dav/lib/Server.php(330): Sabre\DAV\Server->start()\n#29 /var/www/owncloud/apps/dav/appinfo/v2/remote.php(31): OCA\DAV\Server->exec()\n#30 /var/www/owncloud/remote.php(165): require_once(’/var/www/ownclo…’)\n#31 {main}",“File”:"/var/www/owncloud/lib/private/Share20/Share.php",“Line”:173}
what could it be? Asking to the user all seem works as expected (no issue no problem) but the message error continue in the log
I have an owncloud server on ubuntu 20.04 with version 10.6 (scheduled to upgrade next week probably)
Thanks in advance on helòping me.
