- Own Cloud 10 Clean Install Ubuntu 14
- Connect SFTP using Bitvise SSH on Windows 10
- Browse files or attempt to sync with client
SFTP Connection is opened. A batch of commands is executed all at once, for example, listing the contents of an entire selection of sub directories for sync. The connection is closed.
SFTP Connection is opened. Password authentication is completed on the FTP Server. The connection is closed within approximately 5 seconds. This process is repeated countless times apparently once for each folder or subfolder listing. For large datasets, this is thousands of times.
Using the Windows Client occasionally the error message “An error occurs while opening a folder connection closed” is displayed before the process is stopped. Eventually the process will restart.
Windows 10
Ubuntu 14
MySQL
PHP 5
version 10.0.2.1
fresh install
bitnami
SSL Signed
SFTP
no
