I have my owncloud installed at a Shared Hosting Provider. It mostly works well, but I received, as many of you I guess, this E-Mail from owncloud about Security Issues, where I can read that any Version below 10.13.3 is insecure.
When I got to SETTINGS - GENERAL - UPDATER it tells me, that the latest Version is installed (I´m on “stable”), but a little lower I can read that 10.13.2.3 ist installed and I know that 10.13.3.x is available.
Why does the Updater not show this Version? Or when will ist show this Version?
(Yes, I can do a manual Update, but I would like…)
Updating the notification is a manual task, which takes some time. (days weeks …)
But I think meanwhile it should be done, due to its increased importance.
i would always recommend to use the manual upgrade way described by the ownCloud people below once an update is available. From what i have read in the past the updater never worked really reliable.
The manual-upgrade-way was what I did in the past, but the Updater works for me.
(…but now, as I look closer into it, it seems, that the Updater updates OC Core but not installed Apps,
what, as far as I understood, would be the Case when doing a manual Update).
i can remember from the past that i have seen something like "Updating app from marketplacewhen callingocc upgrade`. This seems to also match what is shown in the output the ownCloud people are givinv here:
