Hey there,
I have a problem with the public sharing in ownCloud. It’s possible for me to create and send (via mail) a public link referring to my ownCloud-directory but unfortunately it’s not possible to see the content or upload new files. As mentioned below the following message appears:
“This directory is unavailable please check the logs or contact the administrator”
I’ve checked the logs but there hasn’t been any error message. I appreciate any help you can provide.
- Create a directory for public sharing
- Activate “share link” and “allow editing”
- Visit the shared link to upload some files
The shared directory should be publicly available through this link to download/upload some files.
It’s possible to visit the shared link but the following message appears:
The log file has no error.
Debian 8
Apache 2 .4.10
mysql 14.14
ownCloud version:
9.1.6
Updated from ownCloud 8 some time ago
From the official source as an archive file
"basic": {
"license key": "",
"date": "Thu, 21 Sep 2017 11:00:50 +0000",
"ownCloud version": "9.1.6.2",
"ownCloud version string": "9.1.6",
"ownCloud edition": "",
"server OS": "Linux",
"server OS version": "Linux donovan 3.16.0-4-amd64 #1 SMP Debian 3.16.43-2 (2017-04-30) x86_64",
"server SAPI": "apache2handler",
"webserver version": "Apache\/2.4.10 (Debian)",
"hostname": "donovan.xxx.xxx",
"user count": 32,
"user directories": 32,
"logged-in user": "ocadmin"
"integritychecker": {
"passing": true,
"enabled": true,
"result": []
"config": {
"instanceid": "***REMOVED SENSITIVE VALUE***",
"trusted_domains": [
"XXX.XXX.XXX.100",
"donovan.XXX.XXX"
"datadirectory": "\/home\/data\/owncloud\/",
"overwrite.cli.url": "\/owncloud",
"dbtype": "mysql",
"version": "9.1.6.2",
"dbname": "oc_database",
"dbhost": "localhost",
"dbtableprefix": "oc_",
"logtimezone": "Europe\/Berlin",
"installed": true,
"loglevel": 4,
"maintenance": false,
"trashbin_retention_obligation": "auto",
"enable_previews": true,
"preview_libreoffice_path": "\/usr\/bin\/libreoffice",
"preview_office_cl_parameters": "--headless --nologo --nofirststartwizard --invisible --norestore",
"0": "-convert-to pdf -outdir",
"overwritewebroot": "\/owncloud",
"mail_from_address": "no_reply",
"mail_smtpmode": "php",
"mail_domain": "donovan.XXX.XXX"
Activity, Admin Config Report, Collaborative tags, Comments, Deleted files,
First run wizard, Gallery, LDAP user and group backend, Mail Template Editor,
PDF Viewer, Provisioning API, Share Files, Text Editor, Update notification,
Versions, Video player, Calendar, Contacts, Tasks
No.
Are you using encryption:
No.
Are you using an external user-backend, if yes which one:
LDAP
in oc 10 is new formatting i think…
