Hi, i have a problem with sharing. After digiting group or user to share the folder appear a circle that never stop.
I have the latest version 10.0.7 and i install the app to a siteground hosting.
Thanks for helping me
how did you install ownCloud?
Do you have access to the command line or the log file?
i have used softacolous
i can connect with terminal if necessary
Okay, could you connect and look in the /var/www/owncloud/data/owncloud.log for errors?
You could set the log level on the WebUI to Debug, for detailed output.
