Hi
with the covid19 i have created an owncloud instance for the student of the college (500 persons) .
The php apache service use all of the memory (14go)
I am desespeared because its not my job i search the solution but i dont find
I dont speak english i am french
If you know the rules for a good instance of owncloud i take it if you want help me
Thanks a lot
Eric
oc_filecache
This file is very big 31 mo 150000 lines
I want truncate this file
CenterOs
Apache
mysql
10.4.0.4
Fresh
<?php $CONFIG = array ( 'instanceid' => 'xxxxxxxxxxxxxx', 'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 'trusted_domains' => array ( 0 => 'xxxxxxxxxxxxxxxxxx.fr', ), 'datadirectory' => '/var/www/vhosts/xxxxxxxxxxx.fr/httpdocs/_cloud/_xxxxxx/_prod/data', 'overwrite.cli.url' => 'http://xxxxxxxxxxxxxxxxxxxx.fr', 'dbtype' => 'mysql', 'version' => '10.4.0.4', 'dbname' => '', 'dbhost' => 'localhost', 'dbtableprefix' => 'oc_', 'mysql.utf8mb4' => true, 'dbuser' => '', 'dbpassword' => '', 'logtimezone' => 'UTC', 'apps_paths' => array ( 0 => array ( 'path' => '/var/www/vhosts/xxxxxxxxxxxxxxxx.fr/httpdocs/_cloud/_xxxxxxxxx/_prod/apps', 'url' => '/apps', 'writable' => false, ), 1 => array ( 'path' => '/var/www/vhosts/xxxxxxxxxxxxxx.fr/httpdocs/_cloud/_xxxxxxxxxxx/_prod/apps-external', 'url' => '/apps-external', 'writable' => true, ), ), 'installed' => true, 'maintenance' => false, 'debug' => false, 'enable_previews' => false, 'has_rebuilt_cache' => true, 'cache_path' => '/var/www/vhosts/xxxxxxxxxxxxxxxxxx.fr/tmp/', 'mail_domain' => 'xxxxxxxxxxxxxxxx.fr', 'mail_from_address' => 'xxxxxxxxx', 'mail_smtpmode' => 'php', 'loglevel' => 3, ); ``` Log in to the web-UI with an administrator account and click on 'admin' -> 'Generate Config Report' -> 'Download ownCloud config report' This report includes the config.php settings, the list of activated apps and other details in a well sanitized form. or If you have access to your command line run e.g.: sudo -u www-data php occ config:list system from within your ownCloud installation folder *ATTENTION:* Do not post your config.php file in public as is. Please use one of the above methods whenever possible. Both, the generated reports from the web-ui and from occ config:list consistently remove sensitive data. You still may want to review the report before sending. If done manually then it is critical for your own privacy to dilligently remove *all* host names, passwords, usernames, salts and other credentials before posting. You should assume that attackers find such information and will use them against your systems. ``` https://github.com/62eric43/lazarus/blob/master/config%20report **List of activated apps:** ``` If you have access to your command line run e.g.: sudo -u www-data php occ app:list from within your ownCloud installation folder. ``` **Are you using external storage, if yes which one:** local/smb/sftp/... No **Are you using encryption:** yes/no No **Are you using an external user-backend, if yes which one:** LDAP/ActiveDirectory/Webdav/... With access to your command line run e.g.: sudo -u www-data php occ ldap:show-config from within your ownCloud installation folder Without access to your command line download the data/owncloud.db to your local computer or access your SQL server remotely and run the select query: SELECT * FROM `oc_appconfig` WHERE `appid` = 'user_ldap'; Eventually replace sensitive data as the name/IP-address of your LDAP server or groups. ``` ### Client configuration **Browser:** Edge Firefix Internet Explorer **Operating system:** W10 Education ### Logs #### Web server error log ``` Insert your webserver log here ``` #### ownCloud log (data/owncloud.log) ``` Insert your ownCloud log here ``` #### Browser log ``` Insert your browser log here, this could for example include: a) The javascript console log b) The network log c) ... ```
