More Info: SMBv1 is enabled on the server
I’ve tried removing the php-smbclient and using smbclient but that one is not working properly, the status shows as green even when I enter random stuff in the external storage but then I can’t obviously mount the storage. When I try to enter the right details it still fails and just shows red, with and without specifying a domain, so I’ve gone back to php-smbclient.
What’s really strange is that once I cut a file that throws the error and put it back in the original location it works fine.
The Security permissions on the file are the same when I cut and paste back. No idea what to look for
Double-check you’re using a compiled php-smbclient library for the same php version your server is using. There might be problems if you’re using phpX and the library is compiled for phpY.
In addition, check if the same problem happens with other servers.
I am using whatever is available in the Ubuntu 16.04 repositories.
It doesn’t appear to be a permission issue, I tried scanning the files using the occ, thought maybe they needed to be re-scanned, that didn’t help.
Even if I log in as domain admin and mount the d$ share, it will time out on certain files (no matter the extension) I Just get Secure Connection Failed in the web browser.
DFSR is another component to look into. I’d recommend you to isolate the problem as much as possible. Right now you have quite a bunch of components in a chain, and one of them is failing causing the chain to break.
I guess the chain is something like below.
OC -> php-libsmbclient -> libsmbclient -> DFSR -> SMB server
As far as I know, the apache’s segmentation fault might be caused by problems in the native code of the library. This means that the problem should be reproducible without ownCloud.
https://github.com/eduardok/libsmbclient-php has some examples at the bottom to use the library. I think you can use them to test if the problem still happens or not. If a simple code like that still crashes, the problem isn’t really related to ownCloud.
Thanks for the tip, I’ve used the open example on one of the files I know throws an error and yes I get the same error in Apache. Will try and post on the github
Cheers
i think if a segmentation fault is happening then this looks to me like a serious bug in either Apache or a PHP extension like php-smbclient where ownCloud can’t do anything about it.
So i think the best is indeed probably to report this issue to the php-smbclient bugtracker or as an alternative to update php-smbclient to a newer version.
