The last line in this series of logs does look suspicious, like it isn’t passing a username at all: Invalid request for smb:\/\/192.168.2.23\/Clients\/
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"enter: __construct({\"host\":\"192.168.2.23\",\"share\":\"Clients\",\"root\":\"\",\"domain\":\"\",\"user\":\"SHAREUSER\",\"password\":\"***removed***\"})"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"using native libsmbclient"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"leave: __construct, getId:smb::SHAREUSER@192.168.2.23\/\/Clients\/\/"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"enter: test()"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"enter: stat()"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"enter: getFileInfo()"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"enter: buildPath()"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"leave: buildPath, return '\/'"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"stat fetching '\/'"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"enter: remoteIsShare"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"leave: remoteIsShare, return true"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"enter: isRootDir(\/)"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"leave: isRootDir, return true"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"faking stat for forbidden '\/'"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"enter: shareMTime"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"test swallowing Icewind\\SMB\\Exception\\ForbiddenException - code: 13 message: Invalid request for smb:\/\/192.168.2.23\/Clients\/ (ForbiddenException) trace: #0 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/NativeState.php(72): Icewind\\SMB\\NativeState->handleError('smb:\/\/192.168.2...')\n#1 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/NativeState.php(101): Icewind\\SMB\\NativeState->testResult(false, 'smb:\/\/192.168.2...')\n#2 \/var\/www\/html\/owncloud\/apps\/files_external\/3rdparty\/icewind\/smb\/src\/NativeShare.php(86): Icewind\\SMB\\NativeState->opendir('smb:\/\/192.168.2...')\n#3 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(307): Icewind\\SMB\\NativeShare->dir('\/')\n#4 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(179): OCA\\Files_External\\Lib\\Storage\\SMB->shareMTime()\n#5 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(290): OCA\\Files_External\\Lib\\Storage\\SMB->getFileInfo('\/')\n#6 \/var\/www\/html\/owncloud\/lib\/private\/Files\/Storage\/Common.php(436): OCA\\Files_External\\Lib\\Storage\\SMB->stat('')\n#7 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Lib\/Storage\/SMB.php(643): OC\\Files\\Storage\\Common->test()\n#8 \/var\/www\/html\/owncloud\/lib\/private\/Files\/External\/LegacyUtil.php(202): OCA\\Files_External\\Lib\\Storage\\SMB->test(false, true)\n#9 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Controller\/StoragesController.php(255): OC\\Files\\External\\LegacyUtil::getBackendStatus('\\\\OCA\\\\Files_Exte...', Array, false, true)\n#10 \/var\/www\/html\/owncloud\/apps\/files_external\/lib\/Controller\/StoragesController.php(304): OCA\\Files_External\\Controller\\StoragesController->updateStorageStatus(Object(OC\\Files\\External\\StorageConfig), true)\n#11 [internal function]: OCA\\Files_External\\Controller\\StoragesController->show(23, true)\n#12 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(159): call_user_func_array(Array, Array)\n#13 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Http\/Dispatcher.php(89): OC\\AppFramework\\Http\\Dispatcher->executeController(Object(OCA\\Files_External\\Controller\\GlobalStoragesController), 'show')\n#14 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/App.php(98): OC\\AppFramework\\Http\\Dispatcher->dispatch(Object(OCA\\Files_External\\Controller\\GlobalStoragesController), 'show')\n#15 \/var\/www\/html\/owncloud\/lib\/private\/AppFramework\/Routing\/RouteActionHandler.php(46): OC\\AppFramework\\App::main('OCA\\\\Files_Exter...', 'show', Object(OC\\AppFramework\\DependencyInjection\\DIContainer), Array)\n#16 [internal function]: OC\\AppFramework\\Routing\\RouteActionHandler->__invoke(Array)\n#17 \/var\/www\/html\/owncloud\/lib\/private\/Route\/Router.php(307): call_user_func(Object(OC\\AppFramework\\Routing\\RouteActionHandler), Array)\n#18 \/var\/www\/html\/owncloud\/lib\/base.php(928): OC\\Route\\Router->match('\/apps\/files_ext...')\n#19 \/var\/www\/html\/owncloud\/index.php(56): OC::handleRequest()\n#20 {main}"}
{"reqId":"WdUxL@ZK6PdE3Na1ZOA-YgAAAAc","level":0,"time":"2017-10-04T19:06:23+00:00","remoteAddr":"***removed***","user":"USER","app":"wnd","method":"GET","url":"\/apps\/files_external\/globalstorages\/23?testOnly=true","message":"leave: test, return false"}
