- configured email server settings on CentOS7 / Owncloud 10.5.0.10
- configured email server settings on CentOS8 / Owncloud 10.5.0.10
- same configuration (Redis, http, certificate, …)
no error message and delivered mail
When pressing “send email” I get the following error on CentOS8 (host changed):
A problem occurred while sending the email. Please revise your settings. (Error: Connection could not be established with host smtpauths.masked.ch :stream_socket_client(): SSL operation failed with code 1. OpenSSL Error messages: error:141A318A:SSL routines:tls_process_ske_dhe:dh key too small)
uname -a
Linux homeserver 4.18.0-193.28.1.el8_2.x86_64 #1 SMP Thu Oct 22 00:20:22 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
httpd -v
Server version: Apache/2.4.37 (centos)
Server built: Sep 15 2020 15:41:16
MariaDB [(none)]> SELECT VERSION();
| VERSION() |
| 10.3.17-MariaDB |
php -v
PHP 7.2.24 (cli) (built: Oct 22 2019 08:28:36) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.2.24, Copyright (c) 1999-2018, by Zend Technologies
ownCloud version:
10.0.1.5 (on both servers -> CentOS7 / CentOS8)
CentOS7 updated from “no idea”
CentOS8 fresh install
dnf install …
'mail_domain' => 'xxx.xxx',
'mail_from_address' => 'xxx.xxx',
'mail_smtpmode' => 'smtp',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtpauths.xxxxx.xx',
'mail_smtpport' => '465',
'mail_smtpname' => 'xxxxxx',
'mail_smtppassword' => 'xxxxxx',
'mail_smtpsecure' => 'ssl',
'mail_smtpauthtype' => 'PLAIN',
only install default
NO
NO
NO
Browser: Safari & Chrome
Operating system: MacOS
no entries
