I use owncloud (8.2.7 until a save upgrade plan to 9.x) installed on a NAS.
I try to configure the mail server to use the smtp service of mailjet. And i fail.
When i use TLS / 25, i get the error when i try the test email:
Erreur: Failed to authenticate on SMTP server with username " 3d494c... " using 1 possible authenticators
As you imagine, i have double checked the parameter and if the port is open.
Could it be a problem with owncloud? The server?
How can i check the log?
Thank you in advance for any help.
jb
