1.Setting smtp on both owncloud9 and 10
2.sendign test mail
3.mssages was shown 'The test mail will be sent after setting user mail"(Actually the message is writen in Japanese)
**Operating system:CentOS6 and CentOS7.
**Web server:Apache2.2 and Apache2.4
**Database:mySQL
**PHP version:PHP5.4 and PHP5.6
**ownCloud version:9.0.11 and 10.0.4
**Updated from an older ownCloud or fresh install:
**Where did you install ownCloud from:owncloud.org
No errors have been found.@owncloud10
