I’m trying to connect to owncloud with Solid Explorer, but I’m getting an error when the app is trying to connect.
I’m just using the path to owncloud folder, my username and password.
Does anyone knows if it’s a bug or how to connect properly to owncloud using Solid Explorer?
Hi @davigonz, thank you a lot for the reply.
I managed to connect also. I guess it’s a problem with the SSL certificate on my server.
It’s working perfectly now. ownCloud is great!
thanks
