1. Followed instructions from http://askubuntu.com/questions/48362/how-to-enable-mod-rewrite-in-apache and https://doc.owncloud.org/server/latest/admin_manual/configuration_server/index_php_less_urls.html
url's should be index.php-less
url's are NOT index.php-less
Operating system: Ubuntu 14.04
Web server: ?
Database: ?
PHP version: ?
ownCloud version (see ownCloud admin page): 9.1.2 VMX
Special configuration (external storage, external authentication, reverse proxy, server-side-encryption): Changed web route to '/'
Please paste possible errors in the following code block, see [] for more info
Sorry couldn't get logs.
No connection could be made because the target machine actively refused it.
Connection failed.
Integrity status for oC9+
paste the results here.
I don't know how to transfer the files you requested from my server. I'm running inside a virtual machine on VMware Player. I cannot FTP to my server, connection refused. I tried copying the files to my owncloud/data/username/files but they wouldn't show up on server.
then you might research how to get this stuff from a Virtual Maschine. From my PoV teaching such basics are out of the scope of this forums.
I've done nothing but research for the past 30 minutes. I listed the things I've already tried. Could you please point me in the right direction?
What about using the Clipboard of the VMWare player and just copy the output?
I wasn't able to copy the log in a text format. I don't have a GUI, it is text only. I installed VMware tools by following a guide on the internet and it is work but there's no option to transfer the contents of the clipboard or files to the host. I got thinking though, VMware does let you take screenshots of the guest os and that's what I did. Here you go.
config.phpa2enmodhtaccesshtaccess permissions
the last screenshot shows your issue. The www-data user has no write permissions to write to the .htaccess file.
What permissions do I need to assign it?
Permissions which allows the www-data to write into that file. The following docs might be a good starting point:
I chmod 777 to root, then chown to www-data, ran occ, then restored permissions and owner and it worked. thanks.
