Hi all.
I just installed Oc 9.1 on a new server (debian 8) and I would like to remove the https redirect (I don’t need that).
On my old 8.X version, i just changed the forcessl option in config/config.php, but on 9.1 it didn’t work.
I tried the ‘overwriteprotocol’ option, set to ‘http’ but didn’t work.
I searched on my .htaccess file but didn’t see any protocol redirection.
I’m not an expoert si i could miss something, I’ll copy mly htaccess here
<IfModule mod_headers.c>
<IfModule mod_setenvif.c>
<IfModule mod_fcgid.c>
SetEnvIfNoCase ^Authorization$ "(.+)" XAUTHORIZATION=$1
RequestHeader set XAuthorization %{XAUTHORIZATION}e env=XAUTHORIZATION
</IfModule>
<IfModule mod_proxy_fcgi.c>
SetEnvIfNoCase Authorization "(.+)" HTTP_AUTHORIZATION=$1
</IfModule>
</IfModule>
<IfModule mod_env.c>
# Add security and privacy related headers
Header set X-Content-Type-Options "nosniff"
Header set X-XSS-Protection "1; mode=block"
Header set X-Robots-Tag "none"
Header set X-Frame-Options "SAMEORIGIN"
Header set X-Download-Options "noopen"
Header set X-Permitted-Cross-Domain-Policies "none"
SetEnv modHeadersAvailable true
</IfModule>
# Add cache control for CSS and JS files
<FilesMatch "\.(css|js)$">
Header set Cache-Control "max-age=7200, public"
</FilesMatch>
</IfModule>
<IfModule mod_php5.c>
php_value upload_max_filesize 513M
php_value post_max_size 513M
php_value memory_limit 512M
php_value mbstring.func_overload 0
php_value always_populate_raw_post_data -1
php_value default_charset 'UTF-8'
php_value output_buffering 0
SetEnv htaccessWorking true
</IfModule>
</IfModule>
<IfModule mod_php7.c>
</IfModule>
</IfModule>
<IfModule mod_rewrite.c>
RewriteEngine on
RewriteRule .* - [env=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteRule ^\.well-known/host-meta /public.php?service=host-meta [QSA,L]
RewriteRule ^\.well-known/host-meta\.json /public.php?service=host-meta-json [QSA,L]
RewriteRule ^\.well-known/carddav /remote.php/dav/ [R=301,L]
RewriteRule ^\.well-known/caldav /remote.php/dav/ [R=301,L]
RewriteRule ^remote/(.*) remote.php [QSA,L]
RewriteRule ^(?:build|tests|config|lib|3rdparty|templates)/.* - [R=404,L]
RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge/.*
RewriteRule ^(?:\.|autotest|occ|issue|indie|db_|console).* - [R=404,L]
</IfModule>
<IfModule mod_mime.c>
AddType image/svg+xml svg svgz
AddEncoding gzip svgz
</IfModule>
<IfModule mod_dir.c>
DirectoryIndex index.php index.html
</IfModule>
AddDefaultCharset utf-8
Options -Indexes
<IfModule pagespeed_module>
ModPagespeed Off
</IfModule>
My Server/owncloud is pre-installed by ‘kimsufi’, btw.
