Firstly, I’m not as good at server stuff as the rest of you so please be patient.
I have OC 10.5.0 (stable) on a shared Linux server.
There are two PCs connected: PC1 (Win7) and PC2 (Win10)
Both run OC Client 2.7.6 (build 3261)
Some time ago I had a problem cause by the Hosting provider blocking access
Something similar happened again last night.
I spoke to the Provider today and they confirmed that another rule was blocking me and they removed it.
So now, the connection from PC2 (on the same network and OC account as PC1) works fine.
But all attempts to connect to the OC server from PC1 now gives
Error: Server relied 403 Forbidden to owncloud forbidden to get status.php
The web interface on PC1 works fine.
I deleted the connection in the Client on PC1 and tried to add it again.
I now get the error shown below under “Actual behaviour”.
I have put a link to the owncloud.log file below .
Any suggestions please?
If I need to go back to the hosting provider please can you suggest some suitable words for what to ask?
Thank you for reading this far and for any assistance you can provide.
OC client should connect to the OC server
The client is unable to connect. The server returns
Error: Server replied “403 Forbidden” to “myDomain.com/owncloud/remote/php/webdav/”
- Open Client
- Enter correct server URL and account details
Operating system:cPanel/Linux
ownCloud version: 10.5.0
Client version:
2.7.6
Win7
OS language:
Installation path of client:
Client logfile: Output of
owncloud --logwindoworowncloud --logfile log.txt -
Web server error log:
The owncloud.log file is here. I have changed the first two octets of the IP address.
http://www.zen17229.zen.co.uk/owncloudLogFolder/owncloud.log
