[solved] PageController does not exist
I am developing a small App and have it already running in OC 9.1.0.15. Installing and activating within a new OC runs through without errors. But when I want to enter this app, I get following error message and do not know why:
Exception: {"Exception":"OCP\\AppFramework\\QueryException","Message":"Could not resolve OCA\\OwnCollab_GanttChart\\Controller\\PageController! Class OCA\\OwnCollab_GanttChart\\Controller\\PageController does not exist"
The file pagecontroller.php lies in the folder lib/controller and is registered to the coresponding namespace and extends the controller class
namespace OCA\OwnCollab_GanttChart\Controller;
use OCP\IRequest;
use OCP\AppFramework\Http\TemplateResponse;
use OCP\AppFramework\Http\DataResponse;
use OCP\AppFramework\Controller;
class PageController extends Controller {
As I mentioned the same code is already running on an instance.
Any ideas, what the problem might be?
Best!
Andy
Does no one has a hint what the problem might be?
Hi There,
Did you find any solution for that?
I am trying to create a new app. I am getting the same error.
Thanks,
Smrutikant
