Today I upgrade my personal owncloud server to 10.0.9. The upgrade seemed to have worked at first as I could login and saw the owncloud X logo. It all seemed to work. As I also did some other upgrade and ran autoremove.
After that I could no longer login into and got Error 404. /owncloud/index.php/login was not found on this server.
I did some search but I am not an expert…
SOLVED - Issue came from owncloud.conf file which was empty at /etc/apache2/conf-enabled/owncloud.conf cp it from /etc/apache2/conf-available/owncloud.conf solved the issue.
- upgrade to 10.0.9 using ubuntu repository
- login admin worked
- asked to upgrade
- appeared functional, saw owncloud X login
upgrade to owncloud X
ubuntu 16.04
apache2
mariaDB
php 7.0
10.0.9
update from 9.x
repository
“system”: {
“updatechecker”: false,
“instanceid”: “ocehzd5czb4x”,
“trusted_domains”: [
“chaaberki.fr”
“datadirectory”: “/mnt/ownclouddrive/owncloud-data”,
“overwrite.cli.url”: “https://chaaberki.fr/owncloud”,
“dbtype”: “mysql”,
“version”: “10.0.9.5”,
“dbname”: “owncloud”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“mail_smtpmode”: “smtp”,
“mail_smtpauth”: 1,
“mail_smtpport”: “465”,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“mail_smtpsecure”: “ssl”,
“mail_smtpauthtype”: “LOGIN”,
“memcache.local”: “\OC\Memcache\APCu”,
“maintenance”: false,
“loglevel”: 2,
“appstore.experimental.enabled”: false,
“filelocking.enabled”: false,
“theme”: “”
Enabled:
- comments: 0.3.0
- configreport: 0.1.1
- dav: 0.3.2
- federatedfilesharing: 0.3.1
- federation: 0.1.0
- files: 1.5.1
- files_external: 0.7.1
- files_sharing: 0.10.1
- files_trashbin: 0.9.1
- files_versions: 1.3.0
- files_videoplayer: 0.9.8
- firstrunwizard: 1.1
- market: 0.2.4
- notifications: 0.3.4
- provisioning_api: 0.5.0
- systemtags: 0.3.0
- updatenotification: 0.2.1
Disabled: - encryption
- external
- user_external
no
no
no
### Client configuration
**Browser:**
firefox/chrome
**Operating system:**
ubuntu 16.04
### Logs
#### Web server error log
{“reqId”:“cX/Pui61U8SVNYCKKnG/”,“remoteAddr”:“192.168.1.254”,“app”:"mysql.set$
{“reqId”:“cX/Pui61U8SVNYCKKnG/”,“remoteAddr”:“192.168.1.254”,“app”:"mysql.set$```
