I tried to post all the information requested in logs. The forum only gives bad gateway when posting.
How can I post what is necessary to troubleshoot if the forum won’t take it?
I have a clean install of ownCloud 10.1.0. I get Javascript errors when trying to upload files via the web interface on both Mac and Windows.
Below is all the info I could gather.
I’m not sure how to address the JS issue. I’ve tested with Mac sync client and that works well.
The only issue I have so far the web interface file upload JS error prevent file uploads.
Any direction would be appreciated.
Truncated
1.Clean install of 10.1.0
2.basic default configuration
3. Login with user, attempt to upload any file small or large to folder using the web interface using either ‘+’ icon or drag and drop to window.
The file should be uploaded to the fold active in the web interface.
The progress flashes and no file is uploaded. JS console in browser shows:
h-t-t-p-s://xxxxxxx.com/remote.php/dav/files/uername/Documents/file.pdf 403 (Forbidden) jquery.js:8630
Then:
Uncaught TypeError: Cannot read property ‘documentElement’ of undefined file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:411
I tried current versions chrome, Safari and Firefox on Mac OS 10.13.6. All failed.
I then tried with FireFox 44 and the uploaded process worked. However, ownCload has a message saying to update the browser. When I updated the browser firefox 65 , I received the same failure as the other uploads with current browsers on the Mac.
Centos 7.6
Apache 2.4
MariaDB 10.1
PHP 7.2
System Status
installed 1
maintenance
needsDbUpgrade
version 10.1.0.4
versionstring 10.1.0
edition Community
productname ownCloud
Fresh clean install
h-t-t-p-s://owncloud.org/download/
No local file system only
No
No
Safari 12.0.3 Mac OS 10.3.6
Chrome 71.0.3578.98 Mac OS 10.3.6
FireFox 65 Mac OS 10.3.6
FireFox 65 Windows Server 2012R2 - Tested with RDP client
Mac OS 10.3.6
jquery-migrate.min.js?v=0e09350b2949899f5968b3d22dc1e131:2 JQMIGRATE: Migrate is installed, version 1.4.0
js.js?v=0e09350b2949899f5968b3d22dc1e131:2311 Deprecation warning: tipsy is deprecated. Use tooltip instead.
jQuery.fn.tipsy @ js.js?v=0e09350b2949899f5968b3d22dc1e131:2311
(anonymous) @ backgroundjobs.js?v=0e09350b2949899f5968b3d22dc1e131:26
j @ jquery.js:3099
fireWith @ jquery.js:3211
ready @ jquery.js:3417
I @ jquery.js:3433
(anonymous) @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:1292
dispatch @ jquery.js:4435
r.handle @ jquery.js:4121
trigger @ jquery.js:4350
a.event.trigger @ jquery-migrate.min.js?v=0e09350b2949899f5968b3d22dc1e131:2
(anonymous) @ jquery.js:4901
each @ jquery.js:374
each @ jquery.js:139
trigger @ jquery.js:4900
_trigger @ jquery-ui.custom.js?v=0e09350b2949899f5968b3d22dc1e131:787
_beforeSend @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:826
(anonymous) @ jquery-ui.custom.js?v=0e09350b2949899f5968b3d22dc1e131:405
_onSend @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:941
data.submit @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:674
(anonymous) @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:286
(anonymous) @ jquery.js:3256
j @ jquery.js:3099
add @ jquery.js:3145
(anonymous) @ jquery.js:3255
(anonymous) @ jquery.js:3252
a.Deferred @ jquery-migrate.min.js?v=0e09350b2949899f5968b3d22dc1e131:2
then @ jquery.js:3251
submit @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:285
(anonymous) @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:650
.each..forEach @ underscore.js?v=0e09350b2949899f5968b3d22dc1e131:153
submitUploads @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:648
onNoConflicts @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:1098
checkExistingFiles @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:858
add @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:1120
_trigger @ jquery-ui.custom.js?v=0e09350b2949899f5968b3d22dc1e131:789
(anonymous) @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:1037
_onAdd @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:1030
(anonymous) @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:1276
j @ jquery.js:3099
always @ jquery.js:3246
_onDrop @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:1269
handlerProxy @ jquery-ui.custom.js?v=0e09350b2949899f5968b3d22dc1e131:706
start @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:1133
j @ jquery.js:3099
j @ jquery.js:3099
jquery.js:8630 PUT h-t-t-p-s://example.net/remote.php/dav/files/admin/Documents/file.pdf 403 (Forbidden)
send @ jquery.js:8630
ajax @ jquery.js:8166
send @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:906
j @ jquery.js:3099
_onSend @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:950
j @ jquery.js:3099
j @ jquery.js:3099
file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:411 Uncaught TypeError: Cannot read property ‘documentElement’ of undefined
at OC.FileUpload.getResponse (file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:411)
at HTMLInputElement.fail (file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:1217)
at .(/index.php/apps/files/anonymous function).(anonymous function)._trigger (h-t-t-p-s://example.net/core/vendor/jquery-ui/ui/jquery-ui.custom.js?v=0e09350b2949899f5968b3d22dc1e131:789:13)
at .(/index.php/apps/files/anonymous function).(anonymous function)._onFail (h-t-t-p-s://example.net/apps/files/js/jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:876:18)
at $.(/index.php/apps/files/anonymous function).(anonymous function)._onFail (h-t-t-p-s://example.net/core/vendor/jquery-ui/ui/jquery-ui.custom.js?v=0e09350b2949899f5968b3d22dc1e131:405:25)
at Object. (jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:910)
at j (jquery.js:3099)
at Object.fireWith [as rejectWith] (jquery.js:3211)
at x (jquery.js:8266)
at XMLHttpRequest. (jquery.js:8605)
getResponse @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:411
fail @ file-upload.js?v=0e09350b2949899f5968b3d22dc1e131:1217
_onFail @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:876
(anonymous) @ jquery.fileupload.js?v=0e09350b2949899f5968b3d22dc1e131:910
j @ jquery.js:3099
x @ jquery.js:8266
(anonymous) @ jquery.js:8605
load (async)
send @ jquery.js:8622
j @ jquery.js:3099
End truncated logs
Thanks,
Mike
