Some of pictures are not uploaded correctly
some of pictures are not accessible and the icon does not shows previev…
i think this posting lacks all required information. From what i have seen in the past the forum provides an issue template when creating a new posting and which is asking various detailed info about your setup. I think if you could fill this out maybe more users are able to help you.
ok, sorry, english is not my 1st language, so what information should i write, i think if someone in intereted in help will write here or no ?
the mentioned template i was referring to consists of the following:
