Some users can´t logon into owncloud: Ldap problem
I use version 9.1.0 of owncloud. About fifteen days ago I have problems with ldap. Some users are not able to log into owncloud. It keeps trying to validate and does not leave the screen. I inform that in the test login name, in the Access Attributes tab in the LDAP configuration, we put the login of those users that are not working and when requesting Verify Settings, returns that the user was found and verified settings. I see in the log that the search limit on ldap is 500.
  1. Valid user logging into owncloud.
  2. Stay at the same screen
  3. Time out
Tell us what should happen: User come in into owncloud
Tell us what happens instead: User can’t logging
Operating system: Red Hat Enteprise Linux Server 7.4
Web server: apache 2.4
Database: mysql
PHP version: 5.6
ownCloud version: (see ownCloud admin page): 9.1.0
Update to one of the latest versions. 9.1.0 is no longer supported and it’s quite outdated. There have been several changes around LDAP in the newer versions, so your problem might be solved already.
You might also need to update the PHP version. I think OC 10.1.1 still works with PHP 5.6, but it’s recommended to update to PHP 7.1
