Hi, I have OC running inside a Docker container alongside a separate container hosting an nginx-based SSL reverse proxy. I want to be able to see the real IP of requests in the OC log file so I can feed it to Fail2Ban. If I specifiy the IP of the nginx container then this all works fine. The problem is that that this IP is transient; if I reboot then this container could get a different IP assigned. If I use the container’s hostname in trusted_proxies instead of it’s IP then the requester’s real IP does not get represented in the logs - all requests appear to originate from the proxy.
Does anyone have any possible solutions for this scenario where the proxy’s hostname is known but the IP is not?
Thanks,
Andy
