I’m having a transfer problem on my OwnCloud server. I have the error below!
24-05-02 09:17:06:865 [ info sync.httplogger ]: "6a7a2267-63c7-4576-b2a6-51317747c238: Request: PROPFIND https://cloud.handicarauto.com/remote.php/dav/files/tatane/ Header: { Depth: 0, Prefer: return=minimal, Authorization: Basic [redacted], User-Agent: Mozilla/5.0 (Macintosh) mirall/5.2.1.13040 (ownCloud, macos-23.4.0 ClientArchitecture: x86_64 OsArchitecture: x86_64), Accept: */*, Accept-Language: fr_FR, Content-Type: text/xml; charset=utf-8, X-Request-ID: 6a7a2267-63c7-4576-b2a6-51317747c238, Original-Request-ID: 6a7a2267-63c7-4576-b2a6-51317747c238, Content-Length: 108, Cookie: oclwqad4y8e0=a316a55ea0e70b8183473de0d495cb8c; oc_sessionPassphrase=OL1BeuhrQd8Sj65dPZnj2rFyIEYMSezLqoVxaUfRTIbrR5oxiIOXcOGlMr59M%2Ftjohx8jVgYssy%2FldKK3Te9liSlERd2HPDTTQe8lpPwLs7NJp1UHv%2F75DhSIv1RjZQv, } Data: [<?xml version=\"1.0\" encoding=\"utf-8\"?><d:propfind xmlns:d=\"DAV:\"><d:prop><d:getetag/></d:prop></d:propfind>\n]"
24-05-02 09:17:07:083 [ info sync.httplogger ]: "6a7a2267-63c7-4576-b2a6-51317747c238: Response: PROPFIND 207 (217ms) https://cloud.handicarauto.com/remote.php/dav/files/tatane/ Header: { Date: Thu, 02 May 2024 07:17:07 GMT, Content-Type: application/xml; charset=utf-8, Transfer-Encoding: chunked, Connection: keep-alive, Server: Apache, X-Powered-By: PHP/7.4, Expires: Thu, 19 Nov 1981 08:52:00 GMT, Cache-Control: no-store, no-cache, must-revalidate, Pragma: no-cache, Set-Cookie: oc_sessionPassphrase=OL1BeuhrQd8Sj65dPZnj2rFyIEYMSezLqoVxaUfRTIbrR5oxiIOXcOGlMr59M%2Ftjohx8jVgYssy%2FldKK3Te9liSlERd2HPDTTQe8lpPwLs7NJp1UHv%2F75DhSIv1RjZQv; expires=Thu, 02-May-2024 07:37:07 GMT; Max-Age=1200; path=/; secure; HttpOnly; SameSite=Strict, X-XSS-Protection: 0, X-Content-Type-Options: nosniff, X-Frame-Options: SAMEORIGIN, X-Robots-Tag: none, X-Download-Options: noopen, X-Permitted-Cross-Domain-Policies: none, Content-Security-Policy: default-src 'none';, Vary: Brief,Prefer, DAV: 1, 3, extended-mkcol, 2, } Data: [<?xml version=\"1.0\"?>\n<d:multistatus xmlns:d=\"DAV:\" xmlns:s=\"http://sabredav.org/ns\" xmlns:oc=\"http://owncloud.org/ns\"><d:response><d:href>/remote.php/dav/files/tatane/</d:href><d:propstat><d:prop><d:getetag>"66320f0d8e49a"</d:getetag></d:prop><d:status>HTTP/1.1 200 OK</d:status></d:propstat></d:response></d:multistatus>\n]"
24-05-02 09:17:07:083 [ info sync.networkjob.propfind ]: LSCOL of QUrl("https://cloud.handicarauto.com/remote.php/dav/files/tatane/") FINISHED WITH STATUS "OK"
24-05-02 09:17:07:083 [ debug sync.networkjob ] [ OCC::AbstractNetworkJob::slotFinished ]: Network job finished OCC::RequestEtagJob(OCC::Account("tatane@cloud.handicarauto.com"), "https://cloud.handicarauto.com/remote.php/dav/files/tatane/", "PROPFIND", Original-Request-ID: "6a7a2267-63c7-4576-b2a6-51317747c238", X-Request-ID: "6a7a2267-63c7-4576-b2a6-51317747c238")
24-05-02 09:17:41:791 [ info gui.folderwatcher ]: Detected changes in paths: QSet("/Volumes/SSD/Documents/.~lock.Tableau_miction.ods#")
24-05-02 09:17:41:791 [ debug sync.localdiscoverytracker ] [ OCC::LocalDiscoveryTracker::addTouchedPath ]: inserted touched "Documents/.~lock.Tableau_miction.ods#"
24-05-02 09:17:41:791 [ warning sync.database.sql ]: Sqlite step statement error: 11 "database disk image is malformed" in "SELECT path, inode, modtime, type, md5, fileid, remotePerm, filesize, ignoredChildrenRemote, contentchecksumtype.name || ':' || contentChecksum, hasDirtyPlaceholder FROM metadata LEFT JOIN checksumtype as contentchecksumtype ON metadata.contentChecksumTypeId == contentchecksumtype.id WHERE phash=?1"
24-05-02 09:17:41:791 [ warning sync.database ]: No journal entry found for "Documents/.~lock.Tableau_miction.ods#" Error: "database disk image is malformed"
24-05-02 09:17:41:791 [ info sync.database ]: Closing DB "/Volumes/SSD/.sync_journal.db"
24-05-02 09:17:41:791 [ debug sync.database ] [ OCC::SyncJournalDb::commitTransaction ]: No database Transaction to commit
24-05-02 09:17:41:791 [ info gui.scheduler.syncscheduler ]: Enqueue "/Volumes/SSD/" OCC::SyncScheduler::Priority::Low QueueSize: 0
24-05-02 09:17:41:791 [ info gui.scheduler.syncscheduler ]: Starting sync for "/Volumes/SSD/"
24-05-02 09:17:41:791 [ info gui.socketapi ]: Sending SocketAPI message --> "UPDATE_VIEW:/Volumes/SSD" to SocketApiSocket(0x600001fa19a0)
24-05-02 09:17:41:792 [ info gui.application ]: Sync state changed for folder "https://cloud.handicarauto.com/remote.php/dav/files/tatane/" : "Preparing to sync"
24-05-02 09:17:41:792 [ info gui.folder ]: *** Start syncing "https://cloud.handicarauto.com/remote.php/dav/files/tatane/" client version "ownCloud 5.2.1.13040 979bb9 Libraries Qt 6.4.3, OpenSSL 3.1.2 1 Aug 2023 Using virtual files plugin: suffix OS: macos-23.4.0 QPA: cocoa"
24-05-02 09:17:41:792 [ info gui.folder ]: Forbidding local discovery to read from the database
24-05-02 09:17:41:792 [ debug sync.database.sql ] [ OCC::SqlQuery::prepare ]: SQL prepare "SELECT chunk, transferid, errorcount, size, modtime, contentChecksum, path, url FROM uploadinfo" Try: 0
24-05-02 09:17:41:792 [ warning sync.database.sql ]: SQL prepare failed "SELECT chunk, transferid, errorcount, size, modtime, contentChecksum, path, url FROM uploadinfo" "out of memory"
24-05-02 09:17:41:792 [ warning sync.database.sql ]: Sqlite prepare statement error: 21 "out of memory" in "SELECT chunk, transferid, errorcount, size, modtime, contentChecksum, path, url FROM uploadinfo"
24-05-02 09:17:41:792 [ fatal default ]: ENFORCE: "allow_failure" in file /private/var/folders/n8/pp_chp6x3jlfy1n94r6hdjv40000gn/T/drone-i1eGUVRUE6Wiwc97/drone/src/src/macos-64-clang/ownCloud-5.2.1.13040/src/common/ownsql.cpp, line 292 int OCC::SqlQuery::prepare(const QByteArray &, bool) with message: SQLITE Prepare error
OS: macos-23.4.0
QPA: cocoa
