Sqlstate[hy000] [2054]
Ciao to all!!
Today i have installed apache, mysql and php on my new proliant.
after that i install owncloud.
all works fine but can not start configuration because in the access page of owncloud after i put correct information and click on end conbfiguration the owncloude page answer me:
Error while trying to create admin user: Failed to connect to the database: An exception occurred in driver: SQLSTATE[HY000] [2054] The server requested authentication method unknown to the client
i have try a lot of thing see in google… but i do not able to solve this…
can you help me?
thanks in advance!!
stefano
how about filling the template so we might narrow down ?
Did you try setting 127.0.0.1 or localhost ?
Cheers.
localhost
then:
Operating system : ubuntu desktop 20.04
**Web server:**Apache
Database: mysql 8.0.20
PHP version: 7.2.31
ownCloud version: (see ownCloud admin page) latest 10
Browser: chrome
Operating system: unbuntu 20.04
Could you try with 127.0.0.1 to check ?
Do you have PDO installed, I suggest you check the required modules.
already check with 127.0.0.1 and with the ip address of machine
port 3306 correct?
Default is port 3306 but it depends on your configuration.
Can you login with a simple mysql in the console ?
mysql -u user ...
yes
i will do
now like root or like user?
Well the one you use to create your ownCloud account.
ok i am logged on with workbench
It doesn’t proved the point unless you are using workbench on localhost ?
Check the requirements too as I stated before.
yes i am log in with localhost
if is needed that i log in with shell of php pèls tell me how.
stefanbo
Reporting same problem.
My setup - Ubuntu 20.04 - OwnCloud 10.2.
Command for creating user and granting privileges on owncloud DB had to be separated not as found in instructions).
`mysql> CREATE USER ‘admin’@‘localhost’ IDENTIFIED BY ‘MyPassword1’;
Query OK, 0 rows affected (0.01 sec)
mysql> GRANT ALL ON owncloud.* to ‘admin’@‘localhost’;
Query OK, 0 rows affected (0.00 sec)`
And it is reporting same Sqlstate[hy000][2054] error on database user/password. I am entering -
user: admin,
password: password as above,
database: owncloud and
localhost.
Any news when will OwnCloud support Ubuntu20.04 and php7.4?
This is a mysql configuration issue. You need to allow standard login authentication. A quick internet search with your error message shows the following my.cnf line:
[mysqld]
default_authentication_plugin= mysql_native_password
Just install PHP7.3 via Ondrej PPA until PHP7.4 is supported:
PHP7.4 will be supported with the next release (ownCloud 10.5) which is supposed to be release pretty soon (tm)
Great ! It worked!
Only I did it with:
ALTER USER 'root'@'localhost' IDENTIFIED WITH mysql_native_password BY 'password';
Good for 10.5 - I will wait this version for full deployment.
I’m pretty sure it is not advisable to run a web application with a db root user. I would recommend to create another user with just access to the ownCloud database.
Of course it is not root…Just used this as example:)
Thanx though.
