I would like to import my self-signed certificate created with openSSL into ownCloud (run under Docker).
My self-signed CA certificate works very well with all my services/browsers/etc but when I want to import my certificate in ownCloud I get the error message: “upload an ASCII-encoded PEM certificate”.
I read many documentation but I don’t know which format I must use to be able to import my certificate in ownCloud.
I saw that another Topic as been created for this error but the topic has been closed without a good answer.
I think that a working certificate should be imported in ownCloud without any issue.
If I got error it’s not a problem from my certificate, it’s from ownCloud itself.
So, I can convert my certificate in any format but I need to know which one to use. Is it possible to get this certificate format or any other specific requirement for certificate?
Thank you very much for your help!!
