Install Let’s Encrypt’s Certbot Client
apt install certbot -y
Register your mail address for notifications about your certs
sudo certbot register --agree-tos --email <your-email-address>
Generate Certificates
- Create cli.ini
Enter your mail address used to register with certbot
FILE="/etc/letsencrypt/cli.ini"
/bin/cat <<EOM >$FILE
rsa-key-size = 4096
email = <your-email-address>
agree-tos = True
authenticator = webroot
post-hook = service apache2 reload
EOM
- Create domain.sh
Replace the example with your domain name
#!/bin/bash
# export makes the variable available for all subprocesses
LE_PATH="/usr/bin"
LE_CB="certbot"
# Assumes that example.com www.example.com and subomain.example.com are the domains
# that you want a certificate for
export DOMAINS="-d example.com -d www.example.com"
"$LE_PATH/$LE_CB" certonly --config /etc/letsencrypt/cli.ini "$DOMAINS" # --dry-run
EOM
chmod +x /etc/letsencrypt/cli.ini
- Generate your certificate.
Replace the string with your domain name
sudo /etc/letsencrypt/<your-domain-name>.sh
Now you shuld see similar output:
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/your-domain-name.com/fullchain.pem
Your key file has been saved at:
/etc/letsencrypt/live/your-domain-name.com/privkey.pem
Write down the file paths and enter them in your default-ssl.conf located at
/etc/apache2/sites-available/default-ssl.conf -
Replace the strings in these lines with your newly obtained certificates so it looks like this:
SSLCertificateFile /etc/letsencrypt/certs/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/certs/privkey.pem
- Now Enable SSL for your Server
sudo a2enmod ssl
sudo a2ensite default-ssl
sudo service apache2 reload
- Redirect all unencrypted traffic to HTTPS
Enter this line (adjust for your domain name) in your 000-default.conf somewhere below this line
<VirtualHost *:80>
Redirect permanent / https://example.com/
Like this for example:
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /var/www/owncloud
Redirect permanent / https://my.awesome.website.com/
Restart your web server to apply the changes:
service apache2 restart
Now if you enter the domain name or the IP address of your server you should be redirected to the HTTPS site of your domain.
