- External storage SMB (Netgear ReadyNAS)
- Add external storage access on owncloud (SMB/CIFS) using: host , share, username, password, remote subfolder. Link check green.
- Create a Cron task to update share files: “*/10 * * * * occ files:scan --all”
Correct operation to shared folders of the NAS
I have installed two univention servers with the owncloud application. Client files are stored on a Netgear ReadyNAS.
I have detected that the owncloud windows clients (Client version 2.7.6) show errors: “error transfering https_://IP/owncloud/remote.php/dav/files/USER/FOLDER/ - server replied:Service unavailble”
On server logs show:
“Storage smb::USER@IP_NAS//FOLDER//DIRECTORY/ not available”}
When this failure occurs, owncloud clients do not access their folders but after a few seconds they reconnect. It is a temporary error.
The same thing happens from the web browser, access to the folder fails when clicking, but if you try again a little later it works.
Univention 4.4
apache 2.4.25
MySQL
php 7.0.3
10.4.1.3 and 10.6.0.5
Fresh install
From Univention appcenter
0 => 'localhost',
‘datadirectory’ => ‘/var/lib/univention-appcenter/apps/owncloud/data/files’,
‘dbtype’ => ‘mysql’,
‘dbhost’ => ‘—’,
‘dbname’ => ‘----’,
‘dbuser’ => ‘----’,
‘dbpassword’ => ‘*REMOVED SENSITIVE VALUE’,
‘dbtableprefix’ => ‘oc_’,
‘log_type’ => ‘owncloud’,
‘supportedDatabases’ =>
array (
0 => ‘sqlite’,
1 => ‘mysql’,
2 => ‘pgsql’,
‘upgrade.disable-web’ => true,
‘default_language’ => ‘en’,
‘overwrite.cli.url’ => ‘http://*REMOVED SENSITIVE VALUE’,
‘htaccess.RewriteBase’ => ‘/owncloud’,
‘logfile’ => ‘/var/lib/univention-appcenter/apps/owncloud/data/files/owncloud.log’,
‘loglevel’ => ‘3’,
‘mysql.utf8mb4’ => true,
‘filelocking.enabled’ => true,
‘memcache.distributed’ => ‘\OC\Memcache\Redis’,
‘memcache.locking’ => ‘\OC\Memcache\Redis’,
‘redis’ =>
array (
‘host’ => ‘redis’,
‘port’ => ‘6379’,
‘passwordsalt’ => ‘*REMOVED SENSITIVE VALUE’,
‘secret’ => ‘*REMOVED SENSITIVE VALUE’,
‘version’ => ‘10.6.0.5’,
‘logtimezone’ => ‘UTC’,
‘installed’ => true,
‘instanceid’ => ‘*REMOVED SENSITIVE VALUE’,
‘ldapIgnoreNamingRules’ => false,
‘log_rotate_size’ => 104857600,
‘onlyoffice’ =>
array (
‘verify_peer_off’ => true,
‘maintenance’ => false,
‘onlyoffice’ => array (‘verify_peer_off’ => TRUE),
**List of activated apps:**
No apps
Yes
NAS1: SMB3 and NAS2: no
Chrome
windowsxp, windows 7, windows 10
{"reqId":"tCmICnJbHfqaisdCXZdf","level":3,"time":"2023-02-13T08:34:29+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"--","url":"--","message":"Storage smb::user@LOCAL IP NAS\/\/shared_folder\/\/DATOS\/AURTENETXEA\/L01-AURTENETXEA\/ not available"}
{"reqId":"tCmICnJbHfqaisdCXZdf","level":3,"time":"2023-02-13T08:34:29+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"--","url":"--","message":"Exception: {\"Exception\":\"OCP\\\\Files\\\\StorageNotAvailableException\",\"Message\":\"\",\"Code\":1,\"Trace\":\"#0 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php(457): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->checkAvailability()\\n#1 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Encryption.php(176): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Availability->getMetaData()\\n#2 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Checksum.php(207): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Encryption->getMetaData()\\n#3 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Wrapper.php(587): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Checksum->getMetaData()\\n#4 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(115): OC\\\\Files\\\\Storage\\\\Wrapper\\\\Wrapper->getMetaData()\\n#5 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(152): OC\\\\Files\\\\Cache\\\\Scanner->getData()\\n#6 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Cache\\\/Scanner.php(329): OC\\\\Files\\\\Cache\\\\Scanner->scanFile()\\n#7 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Utils\\\/Scanner.php(246): OC\\\\Files\\\\Cache\\\\Scanner->scan()\\n#8 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files\\\/lib\\\/Command\\\/Scan.php(251): OC\\\\Files\\\\Utils\\\\Scanner->scan()\\n#9 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files\\\/lib\\\/Command\\\/Scan.php(400): OCA\\\\Files\\\\Command\\\\Scan->scanFiles()\\n#10 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files\\\/lib\\\/Command\\\/Scan.php(362): OCA\\\\Files\\\\Command\\\\Scan->userScan()\\n#11 \\\/var\\\/www\\\/owncloud\\\/apps\\\/files\\\/lib\\\/Command\\\/Scan.php(328): OCA\\\\Files\\\\Command\\\\Scan->processUserChunks()\\n#12 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Command\\\/Command.php(255): OCA\\\\Files\\\\Command\\\\Scan->execute()\\n#13 \\\/var\\\/www\\\/owncloud\\\/core\\\/Command\\\/Base.php(159): Symfony\\\\Component\\\\Console\\\\Command\\\\Command->run()\\n#14 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(1009): OC\\\\Core\\\\Command\\\\Base->run()\\n#15 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(273): Symfony\\\\Component\\\\Console\\\\Application->doRunCommand()\\n#16 \\\/var\\\/www\\\/owncloud\\\/lib\\\/composer\\\/symfony\\\/console\\\/Application.php(149): Symfony\\\\Component\\\\Console\\\\Application->doRun()\\n#17 \\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Console\\\/Application.php(165): Symfony\\\\Component\\\\Console\\\\Application->run()\\n#18 \\\/var\\\/www\\\/owncloud\\\/console.php(116): OC\\\\Console\\\\Application->run()\\n#19 \\\/var\\\/www\\\/owncloud\\\/occ(11): require_once('\\\/var\\\/www\\\/ownclo...')\\n#20 {main}\",\"File\":\"\\\/var\\\/www\\\/owncloud\\\/lib\\\/private\\\/Files\\\/Storage\\\/Wrapper\\\/Availability.php\",\"Line\":75}"}
#### Browser log
c) …
