I have installed a nginx server which serves two site one.dev and two.com.
This two website work with https and is fully functional.
I want to install a owncloud server serve by a subdomain oc.one.dev.
I have done/installed :
- mariadb
- nginx (already installed since few month btw…)
- php :
- php7.4-fpm
- php7.4-common
- php7.4-mysql
- php7.4-gmp
- php7.4-curl
- php7.4-intl
- php7.4-mbstring
- php7.4-xmlrpc
- php7.4-gd
- php7.4-xml
- php7.4-cli
- php7.4-zip
- create and set
ownclouddatabase - dl and mv lastest owncloud version to /var/www/owncloud
- set chmod/own
sudo chown -R www-data:www-data /var/www/owncloud/sudo chmod -R 755 /var/www/owncloud/
Next to that i have created a subdomain in my dns : oc IN A SAME.IP.AS.ONE.DEV
I setup the owncloud host :
server {
server_name your_domain;
access_log /var/log/nginx/your_domain-access.log;
error_log /var/log/nginx/your_domain-error.log;
root /var/www/html/owncloud;
location / {
index index.php;
try_files $uri $uri/ /index.php$is_args$args;
location ~ \.php$ {
include snippets/fastcgi-php.conf;
fastcgi_pass unix:/run/php/php7.0-fpm.sock;
Here the oc.one.dev redirect to one.dev.
Next to that i run sudo certbot --nginx, here i set the cert. for oc.one.dev.
Now my host look like that :
server {
server_name oc.one.dev;
access_log /var/log/nginx/oc.one.dev-access.log;
error_log /var/log/nginx/oc.one.dev-error.log;
root /var/www/owncloud;
location / {
index index.php;
location ~ \.php$ {
listen 443 ssl; # managed by Certbot
ssl_certificate /etc/letsencrypt/live/oc.one.dev/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/oc.one.dev/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
if ($host = oc.one.dev) {
return 301 https://$host$request_uri;
} # managed by Certbot
listen 80;
return 404; # managed by Certbot
Now i have a 502 bad gateway in oc.one.dev, for information one.dev and two.com work fine.
Thanks for your help.
if you need other information feel free to ask.
