Stuck in maintenance mode after successful update to 10.0.10.4
I’ve gone through a successful update from 10.0.3 to 10.0.10.4 but after some problems from attempting to update via the web update link in the admin panel.
I noticed that the /config folder which had previously been symlinked to an external disk wasn’t there any longer. I have since copied the config.php file on the external disk to the oc root config directory.
I managed to disable the apps via command-line sudo -u www-data php occ app:disable xyz and do the update sudo -u www-data php occ upgrade. The permission are now hardened, I took the instance out of maintenance mode with sudo -u www-data php occ maintenance:mode --off and the server is rebooted.
My ownCloud instance is still in maintenance mode though. Can there be something still hanging in the database which keeps it in maintenance mode?
Debian 9 (headless server)
Apache
MariaDB
PHP 7.0.33-0+deb9u1 (cli)
ownCloud 10.0.10.4, updated from 10.0.3 from debian package management
Unable to login to above mentioned link as oc instance is in maintenance mode
    "system": {
        "instanceid": "ocbee371e3ba",
        "trusted_domains": [
            0 => '192.168.200.50',
            1 => 'pacolola.net',
        "datadirectory": "\/freecom\/owncloud\/data",
        "overwrite.cli.url": "http:\/\/192.168.200.50\/owncloud",
        "dbtype": "mysql",
        "version": "10.0.10.4",
        "dbname": "owncloud",
        "dbhost": "localhost",
        "dbtableprefix": "oc_",
        "installed": true,
        "forcessl": true,
        "loglevel": "1",
        "mail_smtpmode": "smtp",
        "mail_smtpauthtype": "LOGIN",
        "mail_smtpport": "465",
        "mail_smtpauth": 1,
        "mail_smtpsecure": "ssl",
        "updatechecker": false,
        "maintenance": true,
        "singleuser": false
Enabled:
  - dav: 0.4.0
  - federatedfilesharing: 0.3.1
  - federation: 0.1.0
  - files: 1.5.1
  - files_external: 0.7.1
Disabled:
  - comments
  - configreport
  - encryption
  - external
  - files_sharing
  - files_trashbin
  - files_versions
  - files_videoplayer
  - firstrunwizard
  - market
  - notifications
  - provisioning_api
  - systemtags
  - updatenotification
  - user_external
Are you using encryption: no
[Thu Jan 10 06:25:04.849797 2019] [mpm_prefork:notice] [pid 31116] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2q configured -- resuming normal operations
[Thu Jan 10 06:25:04.849850 2019] [core:notice] [pid 31116] AH00094: Command line: '/usr/sbin/apache2'
[Thu Jan 10 06:35:31.902687 2019] [mpm_prefork:notice] [pid 31116] AH00169: caught SIGTERM, shutting down
[Thu Jan 10 06:35:32.551962 2019] [mpm_prefork:notice] [pid 23815] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2q configured -- resuming normal operations
[Thu Jan 10 06:35:32.552344 2019] [core:notice] [pid 23815] AH00094: Command line: '/usr/sbin/apache2'
[Thu Jan 10 06:37:58.607386 2019] [mpm_prefork:notice] [pid 23815] AH00169: caught SIGTERM, shutting down
[Thu Jan 10 06:37:59.264973 2019] [mpm_prefork:notice] [pid 23860] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2q configured -- resuming normal operations
[Thu Jan 10 06:37:59.265361 2019] [core:notice] [pid 23860] AH00094: Command line: '/usr/sbin/apache2'
[Thu Jan 10 07:03:40.897263 2019] [mpm_prefork:notice] [pid 23860] AH00169: caught SIGTERM, shutting down
[Thu Jan 10 07:03:41.552586 2019] [mpm_prefork:notice] [pid 24181] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2q configured -- resuming normal operations
[Thu Jan 10 07:03:41.552971 2019] [core:notice] [pid 24181] AH00094: Command line: '/usr/sbin/apache2'
[Thu Jan 10 07:51:46.735036 2019] [mpm_prefork:notice] [pid 24181] AH00169: caught SIGTERM, shutting down
[Thu Jan 10 12:22:43.651665 2019] [mpm_prefork:notice] [pid 26799] AH00163: Apache/2.4.25 (Debian) OpenSSL/1.0.2q configured -- resuming normal operations
[Thu Jan 10 12:22:43.652139 2019] [core:notice] [pid 26799] AH00094: Command line: '/usr/sbin/apache2'
Content Security Policy: The page’s settings blocked the loading of a resource at inline (“script-src”).
failed:1:1
JQMIGRATE: Migrate is installed, version 1.4.0 jquery-migrate.min.js:2:542
Deprecation warning: tipsy is deprecated. Use tooltip instead. js.js:2296:2
from what i know the maintenance mode is kept as long as this is set to true in your config.php:
Maybe the occ command doesn’t have write access to the config.php and this is never set to false?
Good point but I’ve double checked that and the fact that the version in config.php is now set to 10.0.10.4 indicates that the occ has write access to the file.
This looks really strange to me. As an alternative you could also set the parameter manually to “false” within your config.php.
The maintenance value is set to false for sure so there must be an other parameter or more likely a failure which insures the maintenance page is displayed.
My best guess is, that it tries to update some apps, thus switching to maintenance mode again.
I switched on maintenance mode on again and turned off the webserver and went through the app list
…and tried turning off the remaining enabled apps. Managed to disable federation but the rest couldn’t be disabled. Now maintenance mode is off and and server restarted. Same situation though.
Have you made sure that you’re actually looking at the correct ownCloud installation and don’t work in a different / other installation location which is served by your web server?
There is only one installation which is located at /var/www/owncloud. As I mentioned earlier the config.php was written to in the last update when the version value was set to 10.0.10.4.
e.g. i was able to access your ownCloud installation via the last IP configured in your trusted_domain settings but still getting the “you’re accessing from an untrusted domain” message which seems to me that the config/config.php you have posted isn’t the one used by your ownCloud installation.
I’ve changed trusted domains just recently, testing if it helps. I will update the original question with what I’ve got now.
FYI I’m getting this repeatedly from tail which I’m running on data/owncloud.log:
{"reqId":"WWcoolL84QVr3ClvUIWw","level":4,"time":"2019-01-10T20:59:38+00:00","remoteAddr":"80.216.185.28","user":"--","app":"caldav","method":"PROPFIND","url":"\/owncloud\/remote.php\/caldav","message":"Exception: HTTP\/1.1 503 System in maintenance mode.: {\"Exception\":\"Sabre\\\\DAV\\\\Exception\\\\ServiceUnavailable\",\"Message\":\"System in maintenance mode.\",\"Code\":0,\"Trace\":\"#0 [internal function]: OCA\\\\DAV\\\\Connector\\\\Sabre\\\\MaintenancePlugin->checkMaintenanceMode(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#1 \\\/var\\\/www\\\/pacolola.net\\\/public\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/event\\\/lib\\\/EventEmitterTrait.php(105): call_user_func_array(Array, Array)\\n#2 \\\/var\\\/www\\\/pacolola.net\\\/public\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(466): Sabre\\\\Event\\\\EventEmitter->emit('beforeMethod', Array)\\n#3 \\\/var\\\/www\\\/pacolola.net\\\/public\\\/owncloud\\\/lib\\\/composer\\\/sabre\\\/dav\\\/lib\\\/DAV\\\/Server.php(254): Sabre\\\\DAV\\\\Server->invokeMethod(Object(Sabre\\\\HTTP\\\\Request), Object(Sabre\\\\HTTP\\\\Response))\\n#4 \\\/var\\\/www\\\/pacolola.net\\\/public\\\/owncloud\\\/apps\\\/dav\\\/appinfo\\\/v1\\\/caldav.php(93): Sabre\\\\DAV\\\\Server->exec()\\n#5 \\\/var\\\/www\\\/pacolola.net\\\/public\\\/owncloud\\\/remote.php(165): require_once('\\\/var\\\/www\\\/pacolo...')\\n#6 {main}\",\"File\":\"\\\/var\\\/www\\\/pacolola.net\\\/public\\\/owncloud\\\/apps\\\/dav\\\/lib\\\/Connector\\\/Sabre\\\/MaintenancePlugin.php\",\"Line\":82}"}
I tried the manual upgrade procedure just recently but came up with the same result.
the posted logfiles looks quite interesting and seems to me confirming my previous assumption:
If you compare this:
with:
(I have redacted your actual hostname)
you can see that you have two different installations side-by-side. I think it is getting even worse when reading this:
From what i know the package management of debian is always installing to /var/www/owncloud and when using a different installation location or moving the location afterwards you can’t keep your installation up to date with the package management.
IIRC the installation via the package management in conjunction with the web updater could make things even more worse: :slightly_frowning_face:
@anon21401411: You’re completely correct. There was an ownCloud instance in the subfolder of the main site. What pain. Thanks for being the second set of eyeballs on the problem. I’ll be off to figuring out how to retain the package management version of ownCloud while making a subdomain to the main site now.
@anon21401411 @alfredb Thanks for the help. :+1:
Hi I had the same issue, but in my case the php opcache had to be flushed!
sudo systemctl force-reload php7.4-fpm.service php8.2-fpm.service
