hi,
My owncloud community edition suddenly redirects back to login page when log in. It shows a message as “you took too long to login please try again now”. But when desktop or mobile clients are used, they log in correctly.
Please help me to sort this out.
sudo -u www-data ./occ status
- installed: true
- version: 10.0.7.2
- versionstring: 10.0.7
- edition: Community
sudo -u www-data ./occ config:list
“system”: {
“instanceid”: “ocq1tbj45qou”,
“trusted_domains”: [
“xxxx.xyz”
“datadirectory”: “/var/www/lrndata”,
“overwrite.cli.url”: “http://xxxx.xyz/”,
“dbtype”: “mysql”,
“version”: “10.0.7.2”,
“dbname”: “oclearndb”,
“dbhost”: “localhost”,
“dbtableprefix”: “oc_”,
“logtimezone”: “UTC”,
“installed”: true,
“mail_smtpmode”: “smtp”,
“mail_smtpauthtype”: “PLAIN”,
“ldapIgnoreNamingRules”: false,
“mail_smtpport”: “587”,
“maintenance”: false,
“loglevel”: “2”,
“debug”: true,
“memcache.local”: “\OC\Memcache\APCu”,
“memcache.locking”: “\OC\Memcache\Redis”,
“redis”: {
“host”: “localhost”,
“port”: 6379
“apps”: {
“backgroundjob”: {
“lastjob”: “13”
“comments”: {
“enabled”: “yes”,
“installed_version”: “0.3.0”,
“types”: “logging,dav”
“configreport”: {
“enabled”: “yes”,
“installed_version”: “0.1.1”,
“types”: “filesystem”
“core”: {
“backgroundjobs_mode”: “cron”,
“default_encryption_module”: “OC_DEFAULT_MODULE”,
“encryption_enabled”: “yes”,
“installedat”: “1520251467.5854”,
“lastcron”: “1521013141”,
“lastupdateResult”: “”,
“lastupdatedat”: “1521005577”,
“oc.integritycheck.checker”: “{"theme-lrn":{"EXCEPTION":{"class":"OC\\IntegrityCheck\\Exceptions\\InvalidSignatureException","message":"Signature data not found."}}}”,
“public_files”: “files_sharing/public.php”,
“public_webdav”: “dav/appinfo/v1/publicwebdav.php”
“dav”: {
“enabled”: “yes”,
“installed_version”: “0.3.2”,
“encryption”: {
“enabled”: “yes”,
“installed_version”: “1.3.1”,
“masterKeyId”: “master_ca48aaed”,
“publicShareKeyId”: “pubShare_ca48aaed”,
“recoveryAdminEnabled”: “1”,
“recoveryKeyId”: “recoveryKey_ca48aaed”,
“types”: “filesystem”,
“userSpecificKey”: “1”
“federatedfilesharing”: {
“enabled”: “yes”,
“installed_version”: “0.3.1”,
“federation”: {
“enabled”: “yes”,
“installed_version”: “0.1.0”,
“types”: “authentication”
“files”: {
“cronjob_scan_files”: “500”,
“enabled”: “yes”,
“installed_version”: “1.5.1”,
“files_external”: {
“enabled”: “yes”,
“installed_version”: “0.7.1”,
“ocsid”: “166048”,
“files_pdfviewer”: {
“enabled”: “yes”,
“installed_version”: “0.8.2”,
“signed”: “true”,
“types”: “”
“files_sharing”: {
“enabled”: “yes”,
“installed_version”: “0.10.1”,
“files_trashbin”: {
“enabled”: “yes”,
“installed_version”: “0.9.1”,
“files_versions”: {
“enabled”: “yes”,
“installed_version”: “1.3.0”,
“files_videoplayer”: {
“enabled”: “yes”,
“installed_version”: “0.9.8”,
“types”: “”
“firstrunwizard”: {
“enabled”: “yes”,
“installed_version”: “1.1”,
“ocsid”: “166055”,
“types”: “”
“gallery”: {
“enabled”: “yes”,
“installed_version”: “16.0.2”,
“signed”: “true”,
“types”: “”
“market”: {
“enabled”: “yes”,
“installed_version”: “0.2.3”,
“types”: “”
“notifications”: {
“enabled”: “yes”,
“types”: “logging”
“provisioning_api”: {
“enabled”: “yes”,
“installed_version”: “0.5.0”,
“types”: “prevent_group_restriction”
“richdocuments”: {
“enabled”: “yes”,
“installed_version”: “2.0.5”,
“signed”: “true”,
“types”: “prevent_group_restriction”,
“wopi_url”: “https://office.xxxx.xyz”
“systemtags”: {
“enabled”: “yes”,
“types”: “logging”
“templateeditor”: {
“enabled”: “yes”,
“installed_version”: “0.2”,
“types”: “”
“theme-example”: {
“enabled”: “no”,
“installed_version”: “1.0.0”,
“types”: “theme”
“theme-lrn”: {
“enabled”: “yes”,
“types”: “theme”
“updatenotification”: {
“enabled”: “yes”,
“installed_version”: “0.2.1”,
“types”: “”
“user_ldap”: {
“enabled”: “yes”,
“installed_version”: “0.10.0”,
“signed”: “true”,
