Switch theme by group
I need Switch theme by group, because I would like having differents appearance In all groups.
¿It’s possible?
Thanks in advance.
Hi dBer,
No, this is currently not possible. Probably you should consider Multi-tenancy here:
Thanks! How can I enable this feature in my OwnCloud?
It is not about “enabling” but rather to correctly plan ahead your setup: you may probably want to have different ownCloud installations, each one with a different theme, and grant access for specific groups to specific instances based on your groups ↔ themes needs.
Then you could use the Federation sharing feature for enabling sharing between groups belonging to separated instances: ownCloud Documentation Overview
I think this is the only way for having this done.
