Sync problems 10.0.4, but 10.0.2 works?
I am using 10.0.4 at the moment. Installed 10.0.4 and tried to sync my devices (here only the calendar on iOS, Thunderbird etc). This does not work. I used the bitnami vm without modifications. The installation is accessible and useable. But no sync with the cal on 10.0.4. The sync URL seems not to have changed and is similar to the older version on 10.0.2… yes for sure, I use another IP on the 10.0.4 as I did on my 10.0.2 :wink:
Anyway… settings on both installations identical, same users etc…
Did I miss something ?
This issue was fixed in 10.0.6 - please update. THX
